Author Topic: Heater Blower Switch on dashboard settings?  (Read 2999 times)
stobart16gears
« on: November 17, 2010, 11:19:35 AM »
Am I correct in thinking that if the heater blower switch in the inline position (same as rear wiper when off), is off, and pushed forward 1 click is on (speed 1), and pulled towards you 1 click (speed 2) in on? If so I think my speed 1 is not working.
126bis1997
Re,. Heater fan.
« Reply #1 on: November 17, 2010, 12:44:52 PM »
I dont think there is a faster speed regards the blower heater fan. Well if there should be then mine is as good as yours mate.! Cheers.
stobart16gears
Re: Heater Blower Switch on dashboard settings?
« Reply #2 on: November 17, 2010, 01:13:23 PM »
Hi, thanks for that, so by that I take it you only have a 1 speed blower or do you think you have 2 speeds but only the faster 1 works?
126bis1997
Re,. Heater fan.
« Reply #3 on: November 17, 2010, 03:24:50 PM »
Its a one speed blower . I had 4 bis cars and all had one and only blower heater speed. And including my everyday bis and yours the total adds up to 6 then ! If you want to be 200% sure I will take a look at the inside of the switch and verify that only one way contacts do exist mate.
« Reply #4 on: November 17, 2010, 04:30:52 PM »
The U.K. version has a 2 speed heater fan :D
stobart16gears
« Reply #5 on: November 17, 2010, 05:12:01 PM »
Thanks everyone for the replys.
I was pretty sure my blower was 2 speed.
« Reply #6 on: November 18, 2010, 08:02:57 PM »
I only had one fast speed by pulling it forward nothing happened if I pushed it but I had a dodgy switch!  Replaced and by pushing it away it had a slow speed!
126bis1997
« Reply #7 on: November 19, 2010, 08:49:40 AM »
So if I were to change my single speed fan blower switch to a 2 way one Id' have a 2 speed blower or do I need to have the necessary wiring for this all PETE 126????????????
Thanks PETER.
« Reply #8 on: November 19, 2010, 05:42:39 PM »
Thanks PETER.
Does your switch push away from you?  If so and it don't work maybe you have a dodgy switch too.....
126bis1997
Re,. Heater fan.
« Reply #9 on: November 19, 2010, 06:27:18 PM »
Yes it does let pull back. So I assume i need to investigate the switch. I admit I was never aware that heater blower fans had 2 speed and now thanks to this forum the more things I learn.! Thanks again .
« Reply #10 on: November 19, 2010, 06:42:10 PM »
« Reply #11 on: November 19, 2010, 09:16:06 PM »
A tell tail sign is check the connections at the back of the switch, if there is 3 wires connected then it should be a 2 speed fan.
As Ciaoflyer said check the switch is not faulty, you can do that with a cheap multi-meter. If its O.K. the slow speed setting goes through a resistor wire that is coiled, usually in the heater fan housing if its broken then that could be the fault [-/
neilW
« Reply #12 on: December 01, 2010, 11:44:16 AM »
I have a BIS and I too have a 2 speed fan. push forward for slow and pull back for fast! he he!
Mine was a little temperamental on the fast speed, you may find the the crimping of the clips inside the plug are not great. I fiddled around with mine so that the connections hug each other a bit better. Also made sure the connections inside the switch were touching properly. (they work on a canter lever system so just bent it a little flatter.
now works perfect!
 :arty:
