Author Topic: Lumpy Acceleration  (Read 1363 times)
Alex
Lumpy Acceleration
« on: September 27, 2010, 09:56:20 AM »
Hello People,
been using the car for lots of small journeys for a long time now,
but over the past week it has started to develop a lumpy acceleration.
i'm slightly baffled by what is causing it, at first i thought dirt in carb, so cleaned it out, and i have fuel filter on fuel line as well.
if i accelerate slowly it doesn't happen but if you put you foot down normally it struggles to go.
Any ideas?
Alex
Re: Lumpy Acceleration
« Reply #1 on: September 28, 2010, 09:24:55 PM »
If the carb is 100% then it may be the fuel pump not delivering enough fuel at a fully open throttle. An engine can also feel weak when the ignition isn't set properly (check that  no.1 cyl piston is before top dead centre at 10 degrees. That's when the points have to open).
