Author Topic: Brake Pipe Threads.  (Read 1698 times)
mark_stoke
Brake Pipe Threads.
« on: September 25, 2010, 12:31:09 PM »
I recently installed all four brake cylinders on my Bis, all the brake pipes were good apart from I broke the one pipe section that screws in between the near side rear cylinder & flexi-hose (the section about 10" long). I took this broken pipe to a garage & they knocked me up a replacement.
The thread on this new pipe will not screw into the cylinder, the thread is metric, the cylinder is new & with a clean thread, I've also tried it in one of the old cylinders that I took off & it will not screw into that either. My Bis is 1991 & my new cylinders are correct for this car & I am told that the threads should be metric.
Can someone please tell me what might be the problem?
Re: Brake Pipe Threads.
« Reply #1 on: September 25, 2010, 06:00:19 PM »
I think Fiat use an unusual 10mmx1.25 thread pitch on their brake unions. The normal metric size unions are 10mmx1.0 pitch. Perhaps someone else could confirm this?
« Reply #2 on: September 25, 2010, 06:17:15 PM »
Yes Chris is correct & the old type Fiat unions are quite hard to get hold of so I tend to refurbish good used old ones but I did manage to pick up a few new ones last year if you get stuck  [-/
mark_stoke
« Reply #3 on: September 25, 2010, 08:23:53 PM »
Thanks for your reply, I left my original part at the garage so if any one has two thread bits spare it would be greatly appreciated.
« Reply #4 on: September 26, 2010, 12:02:26 PM »
Have you got the correct length for that brake pipe  ???
mark_stoke
« Reply #5 on: September 26, 2010, 03:48:40 PM »
It measures 12" long.
« Reply #6 on: September 26, 2010, 06:38:12 PM »
Hi Mark , sorted out a couple of good used unions , a suitable bit of copper brake pipe & I have a professional pipe flaring tool kit so PM me your details & I reckon we can get you back on the road  [-/
