Author Topic: Front Spring Bushes  (Read 1287 times)
Front Spring Bushes
« on: August 28, 2010, 11:04:29 AM »
I am fitting an after market reverse eye spring to my 126, bought new bushes, none came with the spring, they tapped in with a hammer with very little persuasion.  The last time I did this job on my 500 I had to use the vice and an extension rod to force the new bushes in.  Is it critical to have a very tight fit to keep the suspension in the correct shape and working properly after bolting in place or should I strip the spring and have the ends holes shrunk a bit? I have a spring compresor to flatten the spring to the correct shape for fitting.
Re: Front Spring Bushes
« Reply #1 on: August 28, 2010, 11:32:10 AM »
whats the clearance like betwen the kingpin mounts and the leaf spring?
If it's a snug fit it should be ok, but any slack and it's likely to move a little.
 You could shim the gap if there is one.
