Author Topic: 72 mph .. on sat nav? in my bis  (Read 1483 times)
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
« on: February 04, 2010, 03:38:23 PM »
hello there , today after driving 44 miles in bis stoping for ten minutes and trying to drive off .. same trouble .. turned over but would not fire ??
tried easy start .. did nothing ..
just read might be fuel starvation ??? it went after phoning rac and waiting about 30 to 40 mins then everything was ok ?? ..  so cancelled rac .. drove home and got 72 mph on the tom tom go . does that sound about right for a bis thats been sat for 4 years ??  whilst being fixed ?
if so , what do you reccommend ?? new plugs, etc etc ?
richard
fightingtorque
Re: 72 mph .. on sat nav? in my bis
« Reply #1 on: February 06, 2010, 03:02:59 PM »
fuel pump might be suspect .......  i had one that worked when cold but not when engine was hot (I presume because the block expands more than the actuating rod, but the mechanism was also worn.  Letting it cool down for 20 mins it would go again.  For about 10 mins.
72 mph is the book stated top speed, so you are fine there.
bobblehead
« Reply #2 on: February 06, 2010, 03:51:54 PM »
thanks, i have swopped condensor , so will keep a eye out and if need to swop the fuel pump .
thanks for the info
