Author Topic: bis , cinquecento alloys what tire size ? ..  (Read 1792 times)
bobblehead
  • monkeys on the move ..
    • my fiAT 126 PICK UP
« on: November 16, 2009, 02:53:16 PM »
hello there i have a bis pick up, with normal arches, and suspension, what size boots can i put on my cinqucento alloys please? safely without mods ..
165 55 13 ???   ..    or what boots come standard on the cinq alloys and are these ok ??
someone mentioned to me ages ago pirelli p5000 or naikings or something ? .
help someone please ..
Derek
Re: bis , cinquecento alloys what tire size ? ..
« Reply #1 on: November 16, 2009, 08:27:00 PM »
Standard fitment for the Cinquecento Sporting was the Pirelli P5000 which I believe was a 165/55R13. At the time I don't think you could get another premium brand in the same size (they were 165/65R13 which were a cheaper alternative), as a result, the Pirelli's were expensive. The optimum tyre size for the standard alloy I think is 175/50R13.
There is a section on the Forum about what will fit a 126....... http://club126uk.co.uk/smf/index.php?topic=3930
Eklipze3k
« Reply #2 on: November 16, 2009, 09:18:42 PM »
As said, 165/55 13's are standard 'Cento size tyres. Again, there's not a lot of choice but don't get the Nankang's! They are known to 'Cento drivers as "ditch finders".
« Reply #3 on: November 17, 2009, 10:29:18 AM »
I have the same size wheels as a Cinq and initially bought a set of 4 Pirelli 155 65 R13s. It is a very cheap size as is/was standard fitment on many cars from Ford Fiestas to Nissan Micras. you can get budget versions for as little as £9 per boot.
They are a little narrower with larger profile than the 165s, but then again, this usually contributes to a more comfortable ride.
I ended up changing the front tyres as the 155s did rub in the arches on full lock. I changed to Michelin compact 145 60 R13s. which again fit really nice and are of a very low profile. Not as comfortable for the ride, and cost a little more as they are so rare, but they fit in the arches perfectly and make it handle a little more like the original as the tyres are skinnier.
