Author Topic: More Earths  (Read 1412 times)
More Earths
« on: August 27, 2009, 03:55:40 PM »
Just wandering as I am pretty sure I am having intermittent problems due to bad earthing, but can you use more than one earth strap on the A/C engine and if so where would be another good place to have it other than the usual bottom of crank case to rear cross member fitted as standard.
I have made sure my usual earth strap is good and clean, but would like to know if you can reinforce this with one or more (perhaps closer to the stater side of the engine).
Cheers,
Re: More Earths
« Reply #1 on: August 27, 2009, 04:56:02 PM »
You can use as many as you want :D but it should'nt make a difference. on my 126 the earth strap connects from the chassis rail to one of the securing bolts on the starter motor.
