Author Topic: Oil leak!  (Read 1496 times)
Oil leak!
« on: June 02, 2009, 09:05:58 AM »
Thought I'd share this with you...
I had an oil leak, have thought up till now it was from the crank seal on the pulley end but it turned-out after getting covered in muck over the weekend...to be the ceramic bit behind the fuel pump had cracked.
The crack was on the bottom so didn't see it!
Amazing thing is it only leaked if i cranked her up to 65mph and above!
Now I have an annoying intermittent tappety noise...
When the car first starts it isn't there, as she warms-up it appears. But then oddly when she is warm it disappears again!
Only thing I can think of is a sticky valve?? :oops:
Hey ho it's clutch changing this weekend with a little luck, gotta get ready for billing!! [-/
Re: Oil leak!
« Reply #1 on: June 02, 2009, 03:40:22 PM »
Are you sure it is not the little push rod connecting the fuel pump, there are different size gaskets to adjust the distance, if I remember correctly :-
Re: Oil leak!
« Reply #2 on: June 02, 2009, 04:43:34 PM »
Not the push rod.
I threw the rod out and fitted an electric pump.
Helps with starting.
phelps8031
Re: Oil leak!
« Reply #3 on: June 02, 2009, 06:24:11 PM »
I've never taken a fuel pump off a 126, but as it is driven by a cam there must be a tappet between the push rod and the cam, if this wasn't removed it could be the cause of the rattle.
