Author Topic: Seems like carb trouble?  (Read 1902 times)
« on: February 16, 2009, 04:56:33 AM »
Well on my way from work a few mins ago my little fella gave me some trouble, and this is the first time it happened... ill try to explain.
When i start to push the throttle pedal it works ok, then as i get to about half way it completely looses power and seems that revs die to idle speed, and then when i push the pedal all the way the engine jumps to life and revs to max like normal?? what could be causing this? i havent poked around it yet so im asking for your opinion first, all i know its not the cable cos i pulled the throttle lever on the carb with my hands and it did the same thing...  :( any ideas welcome... im off to bed now, hoping its nothing serious...   :oops:
Re: Seems like carb trouble?
« Reply #1 on: February 16, 2009, 11:48:21 AM »
Classic fuel pump rod wear symtom I think.
When the engine gets hotter it becomes a little bigger but the rod stays the same length.
With a little rod wear the pump stops working when it gets hot.
Might have been keeping-up..just but then under load.. :P
« Reply #2 on: February 16, 2009, 12:14:28 PM »
If you have a filter on the petrol feed & the carb is clean I would check that the carb mounting nuts have not worked loose and there are no air leaks at the bottom flange.
« Reply #3 on: February 16, 2009, 01:29:43 PM »
Thx guys, the fuel pump has about 1000km on her, its almost new, and i dont have a fuel filter, illcheck the carb nuts like you said...
« Reply #4 on: February 16, 2009, 01:32:57 PM »
Never mind the pump check the rod is pushing it properly [-/
« Reply #5 on: February 16, 2009, 02:12:21 PM »
huh, i think it wasn't anything like that, one of the spark leads seems to have fallen off the spark plug due to vibration, so i was effectively running on one cylinder... the problem occurred when i started it a few mins ago and once i connected the plug runs great again...  :D [-/
Thanks for your rapid answers guys  :)
While we are on the pump push rod issue, is there some way i can make sure it pushes far enough? just to check it...  ;)
« Reply #6 on: February 17, 2009, 09:17:27 AM »
I used a steel ruler to see how far the rod was pushed out of the engine, then chacked that in fact was far enough to push the pump.
remember there is a little play in the pump before it starts to work the diaphragm.
« Reply #7 on: February 17, 2009, 02:10:25 PM »
Cool, thanx Darrell [-/
