Author Topic: Electricity Issues  (Read 1556 times)
custardboy
Electricity Issues
« on: November 10, 2008, 08:11:38 PM »
Hi there, newbie here had my 86 air cooled just over week and I've broken it already.
Battery went flat after 2 days, was told it was dead as it wouldn't charge and appeared dry in cells.  So bought a new one and car goes fine again, except thought I should check whether battery is not being overcharged, didn't want to ruin another battery, except, nothing when testing battery terminals with engine running.  Shows only 11.95 volts idling on choke?
I have checked wiring to alternator and cleaned up connections.  Battery light on dash lights for couple of seconds when starting then goes out, seems normal there.
Can anyone enlighten me whether likely to be alternator or regulator fault?
custardboy
Electricity Issues
« Reply #1 on: November 10, 2008, 09:42:46 PM »
The regulators don't really have any protection and can easily be fried. Anything from welding on the car with the battery connected, to a chep battery charger with the battery connector.
In my experience it has usually been the regulator that has caused the problem.
You can pick one up from here:
http://www.woodauto.com/Component.aspx?Ref=VRG3662
I've used these guys a few times, very reliable, they charge 1st class postage on top of the unit price which is cheeper than I've found them elsewhere.
custardboy
Electricity Issues
« Reply #2 on: November 10, 2008, 10:50:31 PM »
Cheers for that Michael
I'll order one from them and give it a go.
