Author Topic: ignition lock jammed  (Read 1453 times)
fightingtorque
« on: August 29, 2008, 08:28:31 PM »
Has always been fine, now today I can't get it to go past the 'run' position to the 'start' position, nor will it reliably go far enough back to the 'off' to be able to get the key out.
Managed to get it out a couple of times, but put it back in, same problem.  Can't seem to get it out now.
Has this happened to anyone.
Presumably you have to pull the steering wheel off to get the cowling off.  Once you've done that. can you easily get the lock off the steering column.
It sort of brought a halt to progress - we were about to test the fuel injection.
Also meant I had to come home on one of our other fuel injection prototypes, an ATV. This was the first time I had used it for any road mileage myself and it was a nice evening, so quite fun, although the missus got a stress on about it!
Cheers,
Gav
