Author Topic: Ignition Timing 652cc  (Read 1962 times)
jon.hunt
« on: February 15, 2008, 03:08:56 PM »
Hi All
        I've got my 126 air cooler going with the Panda 30 Head skimmed 1.4mm and the Twin Choke Solex, But I'm having trouble setting the Ignition Timing,  The Car Idles roughly/Lumpy and sometimes Backfires, and if I adjust the Timing I get it to Pink?    It's a Late 87 air cooler 652cc and I've set the Static timing at 10Degrees, I have a Timing Light but not a Rev Counter that will work with 2 Cylinders,  Other than that It goes real well, But I'm sure there's more to come if I could set the Timing Spot on? Any Help Greatly appreciated.
                                                 Jon.
