Author Topic: Weak spark  (Read 1882 times)
kane
Weak spark
« on: February 10, 2008, 05:54:48 PM »
Help!! Spark problems. 126Bis
car will start (only when cold) but stops almost immediately. when i checked at the points while turning over the engine the spark became weaker to the point of no spark at all. would this be the condenser or coil thing ?
Weak spark
« Reply #1 on: February 10, 2008, 08:10:39 PM »
Hi Kane welcome to the forum.
It could be the condenser breaking down, it also sounds as if it could be a fuel problem maybe dirt in the carb. a couple of other things to check.
Make sure that the battery is fully charged as the spark is the first thing to disappear on a low battery.
Check the points are not burnt or pitted. check the points gap and reset the static timing, once you've gone through the basics if its not running check out the fuel side.
kane
Weak spark
« Reply #2 on: February 12, 2008, 08:38:03 PM »
Thanks for the welcome, I think the Forum is Great!
 Done the condenser today , had previously gone through the fuel and carb. I have cleaned up the points a bit and guessed the gap as i dont know what it should be. The battery has a full charge yet when a plug is removed to check the spark it very quicly weakens to no spark at all , say 10 revoloutions. Could it be the coil?
Weak spark
« Reply #3 on: February 14, 2008, 08:44:09 PM »
If you go to the download section you can download the basic information. if the points are out or the timing this can cause this problem, but so can a number of things just work your way through methodically :)
