Author Topic: engine removal - gearbox crossmember  (Read 1904 times)
elbisto
« on: February 06, 2008, 04:43:21 PM »
I am in the process of taking the engine out of my bis and have got almost there, however i am a bit stuck on removing the gearbox cross member from the car.
All it says in the manual is remove the gearbox crossmember from the car. However, I am unsure which bolts to undo, is it the 4 bolts that hold the gearbox mounts onto the body?, is it the two bolts that go through the gearbox mounts onto the cross member? can any one help?
I have to remove the engine without the cross bar and special hook it mentions in the manual so am supporting the block from underneath with the trolley jack, if i remove the gearbox crossmember when do I have to be concerned that the block could squash me? will it be ok in position until i undo the engine mount bolt at the rear? Just dont wanna end up flat!
thanks in advance
« Reply #1 on: February 06, 2008, 11:01:57 PM »
If your not doing any work on the gearbox leave it in, just block it up its less work.
if you need to move the car round with the engine out just cut a piece of wood so it rests back to front and use thick electrical wire to tigh round the wood and one of the holes in the bellhousing.
if you need take the box out undo the bolts that mount the bracket to the chassis.
elbisto
« Reply #2 on: February 07, 2008, 01:34:36 PM »
Ok I am removing the box, so when you say to undo the bolts that hold the bracket onto the chassis, do you mean the 4 bolts in position A on the pic?
just wanna be certain....[/img]
« Reply #3 on: February 07, 2008, 05:53:58 PM »
Hi Mate Remove the A Bolts.
elbisto
« Reply #4 on: February 07, 2008, 10:25:33 PM »
thanks pedro
gives me a chance to install the new mounts that came with the car when i bought it...2 years ago
