Author Topic: the fusebox labling is spectacularly useful  (Read 2349 times)
phreak97
  • Niki!
« on: August 20, 2007, 02:35:50 PM »
hey all, can someone link me to a diagram showing what each fuse does and also what value fuse goes in each slot? i dont have a manual yet..
otherwise, wheres the best place to get power for a stereo? i want it to be on only when the car is on.
thanks
phreak97
« Reply #1 on: August 20, 2007, 04:26:29 PM »
phreak97
  • Niki!
« Reply #2 on: August 21, 2007, 03:03:22 AM »
hmm.. is it safe to just connect it to the on position on the ignition switch? the stereo has its own fuse box..
phreak97
« Reply #3 on: August 21, 2007, 11:13:01 AM »
I would use an inline fuse something like a 3amp from the light blue lead, Try to connect where it is not too visible! Don't cut the wire right through!  solder the connection and insulate the joint. You should then be ok
phreak97
  • Niki!
« Reply #4 on: August 21, 2007, 12:31:15 PM »
what made you choose blue? doesnt that go to the coil? i was going to use black, that's for the lights, and would have less noise on it im thinking..
i am a fan of completely reversable modifications, i was going to do it without modifying the wire loom at all, id either pop that pin out of the connector and make an adaptor to tap 12v off that point, or id see where the wire goes and find another place to connect to.. i dont like soldering to original wires.
phreak97
« Reply #5 on: August 21, 2007, 03:53:41 PM »
if you want reversable just go directly to the battery and then place an inline fuse and the radio has a on/off so will not be on unless you do so?
« Reply #6 on: August 21, 2007, 04:32:47 PM »
Blue lead is the one which is powered with ignition switch on!
Rechecking the wiring diagram you can pick this lead up at the fusebox Fuse 1 or A. Still use an inline fuse on the radio power feed.
phreak97
  • Niki!
« Reply #7 on: August 22, 2007, 01:11:46 PM »
this radio has had a history of flattening batteries even when switched off, i definately need it connected properly. anyway, the red wire is the one which comes on to kick in the starter motor, my niki is different to that diagram, i have four wires. brown is 12v into the switch, blue and black are both on when the ignition is in the on position, and red is on when the ignition is in the start position. i pretty much have it figured now, all except for where im going to fit a speaker or two.. the speaker place doesnt have enough space.
thanks for the help! even though i just ended up figuring it out myself, having a wiring diagram gave me the motivation.
phreak97
