Author Topic: waxoiling  (Read 8025 times)
richard
safety safety
« Reply #15 on: April 23, 2006, 08:36:22 AM »
i am only going to do it the once .....
and i will be as safe as i can be with the materials avaliable
did a little more prep work to the 500 yesterday progress can be seen at :
www.dropshots.com/richemon1    and
previous work at
we are going to red oxide the lot ...   first , fit all the stuff on then fix brakes and lights etc ...... then mot  ..
once motd can think about where to do this final coat of 2 pac  .......
william
waxoiling
« Reply #16 on: April 23, 2006, 09:17:52 AM »
what clolour is the 500 gonna end up yellow
it will lok superb when it has finished
Chris Lakin's Nephew
aircooled head
waxoiling
« Reply #17 on: July 18, 2006, 08:51:41 AM »
2 pack paint contains cyanate which is derived from cyanide, and is very bad for you as it coats the inside of your lungs and cannot be removed, a normal charcoal filtered mask is useless.  Ifyou insist on using  it, you should use a air fed mask like the professionals use, which is cheaper than poor health in the long run.
richard
waxoiling
« Reply #18 on: July 18, 2006, 09:07:16 AM »
its gonna be ferrari red william ..
and ive got a mask ..and suit etc etc . so should be ok #
neil 126
waxoiling
« Reply #19 on: July 18, 2006, 10:10:36 PM »
not all 2 pack paints contain syanide, i use 2 pack piant regularly and there is no cyanide in there, i've checked.
learnt it the hard way
