Author Topic: Engine test frame - Wiring  (Read 1751 times)
joda
« on: April 25, 2016, 10:51:54 AM »
 Iam in the process of building a engine test bench as i have several Bis engines i wish to get runing before selling or stripping
 Can anyone advise how to wire it so that i can run the engine?
126Bis
Da Londo
    • Fiat 126 blog
Re: Engine test frame - Wiring
« Reply #1 on: April 25, 2016, 02:01:03 PM »
Maybe this will help?
joda
« Reply #2 on: April 26, 2016, 09:06:37 AM »
 Thank you , that does help, however, what is 60250 on the diagram? where the cable from the coil runs to?
 John
126Bis
Da Londo
    • Fiat 126 blog
« Reply #3 on: April 26, 2016, 01:08:54 PM »
It's not mentioned in the legend but it has to be the resistive wire, so you will need a ballast of some sort but I'd like some input drom others. Maybe not needed in your test setup?
« Last Edit: April 26, 2016, 01:22:42 PM by Da Londo »
