Author Topic: Filler  (Read 2165 times)
cider
Filler
« on: September 06, 2015, 11:29:42 PM »
Hi All
Now the children have gone back to school I now have me and fiat time :D
Whats the best filler on the market as I need to skim over the welds
Pete
Re: Filler
« Reply #1 on: September 06, 2015, 11:49:27 PM »
The last filler that I used was U-POL'D' Metallic Filler Paste, which I found to be excellent. For a perfect finish use a Polyester type stopper for finishing off.
Re: Filler
« Reply #2 on: September 07, 2015, 08:04:17 AM »
I always use 3m filler- Its easy to sand and doesn't get lots of pin holes in it- go to your local paint factors not halfrauds and get what the professionals use.
Bambino126
Re: Filler
« Reply #3 on: September 07, 2015, 08:44:26 AM »
I must be a novice, because I use good old P40, with a thin coating of P35.
Re: Filler
« Reply #4 on: September 07, 2015, 09:02:16 AM »
To be honest there's nothing wrong with most fillers they are fundamentally the same, the cheaper ones can be harder to sand and if you've got a whole car to skim (a situation I've been in more than once) you're thankful for it being that little bit easier.
cider
Re: Filler
« Reply #5 on: September 08, 2015, 09:03:47 PM »
Thank you  :)
