Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: f40fanatic on August 04, 2015, 08:57:39 PM
Title: Bis rear shock STUCK!
Post by: f40fanatic on August 04, 2015, 08:57:39 PM
Trying to remove my rear shock, and the bolt holding it underneath wont budge, anyone else had this issue? Its undone and moves, but wont come out of the hole...
Title: Re: Bis rear shock STUCK!
Post by: Gadge on August 04, 2015, 10:04:27 PM
Have you got a small punch to drift it out with? Try using a trolley jack to relieve some of the weight of the arm as you tap it out
Post by: stuey on August 05, 2015, 09:58:03 AM
Soak it in wd40, put the nut a few turns on the end then use a sacrificial socket/piece of wood/metal and drift it out with a large hammer, obviously it will get stuck at some point with the nut on it but by the time it does it will be loose enough to wind out with a socket and it always happens when I try to remove mine.
