Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: mintex on April 01, 2015, 04:42:06 PM
Title: rear engine mount (the sprung one)
Post by: mintex on April 01, 2015, 04:42:06 PM
Hi all.
do all the fiats use the same rear engine mounts, ive changed the front gearbox ones and its much better and looking at the state of them i guess the engine sprung one wont be much better so i want to change it.
Its this the set i need for my bis please?
https://webshop.fiat500126.com/katalog/artikelinfo/1720/set_of_rubber_bearings_for_engine_mounting_3_bearings
 :D
Title: Re: rear engine mount (the sprung one)
Post by: mintex on April 01, 2015, 04:59:12 PM
Or this one as  :)
https://webshop.fiat500126.com/katalog/artikelinfo/2718/set_of_rubber_bearings_with_spring/2718
Post by: Gadge on April 01, 2015, 08:21:14 PM
I belive the BIS and aircooled mounts are different. I think there wider?
Post by: mintex on April 01, 2015, 08:24:40 PM
i cant seem to find anyone listing a rear mount for a bis  :(
Post by: Bambino126 on April 03, 2015, 06:29:26 PM
if you find out, let me know because i've got to do mine too.
Post by: mintex on April 05, 2015, 08:41:18 PM
Will do, i plan to order one tuesday so once it arrives i will let you know   :)
Post by: mintex on April 11, 2015, 10:42:43 PM
Well i bought a new mount.
Its not quite the same but it fits and it has reduced the vibration.  It looks like the bis has a larger top rubber as it has a metal plate on the spring but with the new rubber i had to remove this.
The new one
(http://i128.photobucket.com/albums/p161/suzuki998/Fiat%20126/20150411_132414_zpsenq2ngje.jpg)
The old one
(http://i128.photobucket.com/albums/p161/suzuki998/Fiat%20126/20150411_132357_zpsyrk0q6mx.jpg)
old and new
(http://i128.photobucket.com/albums/p161/suzuki998/Fiat%20126/20150411_132053_zps6k7nnmof.jpg)
old and new
(http://i128.photobucket.com/albums/p161/suzuki998/Fiat%20126/20150411_132047_zpsivxbrgvd.jpg)
Post by: scotty on July 17, 2015, 11:42:05 AM
How did you go on with the air cooled mount on the Bis in the end?
I've got to sort mine out. BOO! :(
Post by: mintex on July 19, 2015, 07:48:18 PM
It did fit but the top rubber is a little smaller and i had to leave out the metal plate out but it did the job. I never found anyone listing one for the bis but somebody must do  :headscratch:
Post by: scotty on July 19, 2015, 08:48:01 PM
I've not found anywhere that sells them. :(
Thanks for that.
Mine pinged off after the thread stripped and I think I lost part of the rubber judging by the clunking I get in reverse and over bumps.
Think I'll order one and give it a whirl.
Post by: Bambino126 on July 20, 2015, 04:15:19 PM
http://www.fiatclassic.com/HTML126/KATA126U.HTM#engine
Item 1765
Is that the right one?
Post by: mintex on July 20, 2015, 11:32:00 PM
I dont think so, that looks like the same kit i bought :(
