Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: AlleyNiki on March 17, 2015, 01:47:37 AM
Hi guys, long time no see!
I was just wondering what sort of rpm / bhp the standard aircooled crankshaft can tolerate?
If I wanted to do the Panda head / carb upgrade can I keep it standard?
well i don't know about bhp but the best person to ask is smallcox(steve) because he has broken one but i know he told me that 60bhp would be ok.
as for rpm, i have had mine at between 9000-10,000 rpm severall times and it's still kicking if you know what i mean.
Mics126 - 9000-10.000 rpm? How did you manage that?
Smallcox actually broke two I think.
If you don`t go crazy on the mods the standard crank will be fine. There are some who say the bis one is stronger. Rusty`s Uncle is using one of them in his AC.
Thanks for the responses guys. I'll see if I can get in contact with Smallcox. :)
i managed that racing around on the dual carageway to and from work entering the roundabouts at about 40-45 mph dropping down into 2nd gear. i only found out it was that high rpms when i fitted a revcounter (tachometer) and after i realised that i only went to about 7000 rpm which still screems a bit but its propably safer.
You may want to read this ;)
http://club126uk.co.uk/blitzracing/tuning.htm
