Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: Da Londo on January 17, 2015, 12:05:46 AM
I've learned a great deal about many thing here on the forum and one of 'em was that a 40/80 cam would also be called a 300 degrees cam (correct me if I'm wrong). But now I go on ebay and find a cam like this: 40/80 110* 7,60 lift. What is this 110* and is 7,60 okay for lift? The swiatek does 7,20. Ebay number: 231295716159
Ah, Swiatek site back online. 110 degrees is Alpha angle.
??? What is alpha angle?
Kałuża has better camshafts than Świątek...
You have a website for Kałuża?
Kałuża hasn't own website. Sometimes he doing camshafts - it's a strange situation.
I have some new camshafts of Kałuża project
Can you give me the specs from that camshaft?
Camshaft 555
Lift cam 7.8 mm 7.8 mm
Valve opening 41 st. 72 st.
Closing the valve 61 st. 30 st.
arrangement of valves - a cold engine 0.15 mm 0.10 mm - a cold engine 0.15 mm 0.10 mm
Can you explain what makes this one better?
