Fiat 126 Chat => Fiat 126 Chat => Topic started by: Gwtaylor on January 03, 2015, 01:22:53 PM
Since telling my mates I'm getting a little 126 my mate has jumped on the band wagon aswell and he wants one as well l. He's spotted a LHD but wants to know if it's hard to convert a LHD into a RHD?
Is there a point though?
Mine is LHD and there is no problem switching, besides with the car size you,re sitting in the middle of it anyway :D
Exactly what I said
But he's found a cheap LHD but he likes the steering wheel to be on the propper side
What's involved
I'm assuming
New steering rack
There's probably a lot more work involved than just changing the steering rack. Pedals, dashboard, speedo and there many other bits and pieces needed. Best to source a RHD donor car (unrestorable) for the bits if you want to go down the RHD route.
Yes it's much more complicated. You'll need to cut holes for the steering rack and for the speedo cables and dash wiring. Then you'll have to fit the pedals over from the other side so you'll need to drill/fit new mounting points and you'll need a RHD Accelerator pedal as the LHD one is different. You will have to repostion the brake master cylinder as the brake pedal fits directly into the back of it (unless you can fashion some sort of linkage system up to the other side) then you'll need a RHD a rack (thin on the ground).
Ha just showed him all the thread he's now sticking it out for a RHD model
