Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Bolek on October 10, 2014, 08:34:50 AM
my car drives well at lower speeds but on the highway it wanders and sways like crazy, rocking back and forth and all over the place! a bit unsettling.
Anything specific to the maluch that could cause this? I made sure air pressure was factory, and front steering bushings mostly new.
is it time for an alignment or what else could it be?
Maybe your shocks? Give each corner a good bounce and see how many times it goes up and down before it stops moving. Any more than 1 and and half times then your shocks are bust and need replacing. If there ok then have a look at your steering knuckles
Hi, check your rear bearings then rear toe angle as positive toe on rear is bad news and will cause an unsafw. ride
so I figured out the problem - thanks to good old google! found a thread about some guy's WRX with the same problem, he got new tires installed and car started wandering.
sure enough - my front tires are quite new (like this when I recently bought the car) and rears fairly worn.
A quick Tire swap front-to-back and the wandering is gone! :) Car is high speed very stable and handles beautifully.
(that said I did still inspect shocks and some oil leaking at front - although the bounce test reveals they are still absorbing shock well)
