Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: poxxxy on October 08, 2014, 08:34:46 PM
I'm wondering whether the figures here make any sense or if the values i've put in for when the valve opens/closes are even right... just wondering as if the tailpipe has to be that long its going to be interesting to mount it :D.
The BBDC and ATDC openings I found on a 500 build log but I have a feeling with the bis camshaft thats not quite right...
(http://oi60.tinypic.com/2m7hlr9.jpg)
I'm not sure if it's right but the issue is where do you want your main power band(torque cures) i know there is more of a science to it and i know a fair amount.
but the basics are: longer for more low down power. smaller diamiter again for lower down. and where you connect both down pipes (of corse more important with more cylenders) again more distance away from the valves more lower down power.( of corse opposie to what i have said is for higher power)
the same sort of principles are true with the inlet which is very important to get set up as well for natrally aspirated engines and as you may have probbably worked out is the inlet seriously effects the design of the exhaust for maximum efficiancy where you want the power.
There is alot more i would like to talk about but its one of those talk in person subjects but i have put the basics down.
Mike
