Fiat 126 Chat => Fiat 126 Chat => Topic started by: baron_matt on July 10, 2014, 12:56:22 PM
Well first day in the workshop for our Fiat 126 for its Kingpin work and we have run into issues.
The new kingpin set won't fit the spare hub set I have and the kingpin carrier on the car has been damaged in its past preventing the bottom plug from ever fitting.
Looks like I'll be getting and fitting a recon stub axle after all.
On top of this it seems that only one half of the wheel cylinder is actually working each side at the front and the drums are oval which accounts for the appalling braking. There is a great deal of work a head to make this car match fit for an MOT.
Why won't it fit the spare hub that you have matt?
Gadge it seems that there is a difference in size between the kingpin bush in the kit and what is present on the sub axle.
Rusty has come to the rescue thankfully, we should get this car back on the road soon I hope.
should anybody else need kingpin renewal, I happen to have a set of the Fiat tooling to undertake this :)
I took a pair of new/refurbished stub axles down to the garage yesterday so Matt can get his car fixed. Had a chat with the mechanic and the problem was not with the bushes but the actual axle eye where the king pin is supposed to lock solid with the roll pin. It was loose and I had exactly the same problem with some new ones about 2 years ago. The damage would have been caused by a major shock /trauma to the suspension which seems to be a part of everyday motoring now with the state of the roads we have to drive on >:(
Shock trauma is a good description. I can' wait to have a working front spring again.
The latest update is that the front spring, spring carrier and stub axles are now on.
Front brake cylinders are in, as are new shoes, new drums are also going on too so a complete front end brake over haul has taken place now too.
MOT is due today so fingers crossed...I just have a nasty feeling that it will fail on something else now. >:(
Thanks again to Rusty for helping.
One thing I am certainly looking for is the clamp thing that holds the battery down.
Anyone got a spare on kicking about?
Matt
Well, the garage have just called and our 126 is now finished.
New front brake drums - (supplied)
New front brake cylinders - (supplied)
New front stub axles - (supplied)
New front spring - (supplied)
New Brake Master cylinder - (supplied)
New Nearside wheel bearing - (supplied)
New front spring carrier and bushes - (supplied)
Gearbox oil change with correct stuff. - (supplied HOW MUCH!)
MOT
Headlight bulb
They are working out the bill as it is said to be a bit high. Hoping that they are OK to hold onto the car until next week when I get paid.
The car was originally booked in for the fitting of a new front spring, n/s kingpin fit and an MOT. To quote Vinny Jones......It's been...emotional.
Wow, I guess your be doing a bit of overtime, but it will be worth it.
MOT
Headlight bulb
Yeah you are not wrong there.
I'm going to convert back to standard steel wheels with tall 80 profile tyres to give the suspension an easier time.
We don't have the table smooth roads of France of Germany anymore.
If you want lumpy roads, try Norfolk!
Well I have the car back and a shiny crisp MOT certificate in my hand.
The first ride home was interesting as the brakes all now work and the car pulls up on a 5p piece, however the pedal seems to go a long way before the car stops.
I thought it was due to air in the system at first but pumping it makes no difference and good pressure is felt.
Rusty has mentioned that sometime the adjusters take a while to stick in the correct positions. Hopefully it is just that, anyone got any hints on how to make the adjusters.
I still have a clonk noise coming from the front end, but now where near as bad as it was and the car rounds corners without feeling like the wheels will come off, so that's a bonus.
However not content with all this expenditure, the Fiat decided that with an MOT now achieved it would completely shatter its brake light switch into two parts on the way home.
heavy sigh
