Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: mossfred on May 25, 2014, 05:46:05 PM
Im new to the forum, had a modified (by MBG) 650 with FZD for many years and am building a hopefully fast motor myself this time.
I need some advice on carb and cam. The motor is a 600, i can get a new set of 650 pistons and barrels (Polish) cheap from Holland, worthwhile, or should i think bigger, dont really want to spend the$$?
Should i go for a dellorto fzd 32/26 or a solex 34 PBIC? FD offer a 40/80 300deg cam or should i go for the swiatek R385? I have a ported big valve head and light flywheel
Any good advice welcomed!!
Fred
Why not simply fit a 650 engine first and see what you think.
Then start modding that?
Hi Fred , welcome to the forum. I guess that you know that you cannot fit 652ccs barrels to a 594 crankcase without having the crankcase bored out so if you are going the 652 way you might be better off starting with a later 126 crankcase but do not go for the later Polish ones otherwise you will not have a hole to drop your distributor in. Sounds like you have the head sorted, is that a 500 flywheel you are using ?
I would suggest that you have a trawl and search through the tuning section on the forum and you may find some answers there :)
I was going to bore the crankcase. I have read every post on the forum, but didnt really find out much if anything about using the Solex/Weber 32PBIC, i have a Dellorto on my other motor but its 3 times the price of the Solex/Weber 32. As for the camshaft i found out about Swiatek on this forum but am curious if anyone has used/compared to the generic Abarth copy on offer from FD (the 40/80 300 deg cam). The flywheel is from FD and i guess its specially made as opposed to a lightened standard type!
Fred
Hey mossfred, I suppose you don't remember what jetset was used in that FZD?
Sent from my HTC Desire X using Tapatalk
Hi Da Londo
Its been 10years since i had to re-jet it after picking it up from MBG. The car is in the bodyshop, next time i visit i will have a quick look see
In case anyone is actually interested, i have built the motor now, 704 cc, 40/80 cam 2.5kg flywheel, Solex 34 PBIC on the Abarth valve cover and big valve ported and skimmed head. A lot of machine work was required to put these parts together. Will dyno it soon and post results.
I`ll be watching the results with interest on this one.
Have you actually had the engine running yet? How does it behave with such a light flywheel?
Great!
Hi Da Londo
