Fiat 126 Chat => Fiat 126 Chat => Topic started by: cider on May 07, 2014, 03:32:22 PM
Hi All
I`m looking to replace all the brakes on our bis ,Are the drums/cylinders and shoes the same on both
front and rear
Thank you
Julia
The drums and shoes definalty are not sure on the wheel cylinders though?
Yep, wheel cylinders all the same on the BIS.
Keith
Hi Julia , have you considered a front disc brake conversion while you are at it ?
Hi
Thank you for your help :) :) Hopefully discs on the front is the plan at some point
Julia
Does this produce a good improvement on the later (eg BIS) cars with larger drums? Reason I asked is now my drums have bedded in the brakes are not too bad on our BIS. They just "feel" a bit wooden due to lack of servo. Does a front disc conversion improve "feel" as well as outright stopping ability?
Keith
There a great upgrade to have, I've found they feel the same but stop the car so much quicker. My biggest concern was them being too good and locking the wheels but there actually just right. Never locked them up once :)
Sounds tempting... Where did you get the conversion kit from?
I bought the brackets off eBay for about £25 and then just bought a set of punto calipers and some cross drilled punto/seicento discs. Forget those companies selling kits for £500 I did it for less than £120
I agree I have done 3 disc conversions all for about £120 ish. The cheapest was 20 for the plates, 25 for a set panda callipers including cradle and vw flex hoses at 10. This setup is on my Gamine, 7 years with no problems. If you are mixing and matching check the alignment of the disc and caliper, I had to shim out to get one conversion just right, I used stainless washers for the shims.
Wow at these prices how come we don't all have disc brakes?
To do the conversion for these costs you have to search round the breakers to get the best price. Good hunting.
The hardest part (and it's not really that hard) is getting the adaptor plates. The rest is readily available from breakers yards and motor factors. It's not even that hard to change them around if your mechanically minded. I really don't know how some of these companies can charge as much as they do
So where do you get the adapter plates?
Check out eBay, the adapter plates come up regularly I saw cinq, semi and pinto callipers ranging from £25-£40 including carriers. There is a drawing for the adapter plates on a Polish site. If you search this site you should get a link.
I made adapter plates using the diagram from a Polish 126 site see http://www.126fan.pl/ look under heading Tuning Zawieszenia, Hamulce Tarczowe. You will find all the information to carry out the modification.
