Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: essex southend on March 14, 2014, 06:35:26 PM
Title: Gearbox Oil
Post by: essex southend on March 14, 2014, 06:35:26 PM
Thinking I could be dim but I want to top the gearbox oil up but I can't find where the plug is located,  can any one help or post a picture for me.
Thanks again
Title: Re: Gearbox Oil
Post by: Gadge on March 14, 2014, 07:41:17 PM
It's on the side by the starter motor. Looks like a square 1/2 inch plug.
Post by: Scarlettkitten on March 14, 2014, 07:41:48 PM
If it's a BIS its on the drivers side of the gearbox, 13mm square ended plug.  I've just topped mine up :)
beat me too it /\ :)
Post by: essex southend on March 14, 2014, 07:46:23 PM
Thanks,  I think that it has been located,  it has an oversize bolt in it, will try and post a picture.
Post by: essex southend on March 14, 2014, 10:27:10 PM
Is this where the gearbox oil filling should be?
Post by: andyzeetec on March 14, 2014, 10:51:04 PM
This is it on the bis, not sure if aircooled is the same...I found this pic some time ago.
good luck with undoing it, had a go at mine today and cant budge it, had a search tonight on the forum and found this method which I have yet to try, but sounds good...
"use a short 1/2" drive socket extension , reverse it & tap it onto the square plug head then it is easy to get a spanner on the square end of the extension and makes it much easier to get a good hold on the plug"
Post by: 126blackbird on March 15, 2014, 09:53:07 AM
Make sure you use the right oil.........................don't use EP oil
Post by: essex southend on March 15, 2014, 10:00:54 AM
Thanks Blackbird...looking at my photo is this where I should top up?  thanks
Post by: Bambino126 on March 16, 2014, 07:14:27 PM
Try this:
Take a 12 mm half-inch drive long nose socket, preferable a hexagonal one as opposed to the bi-hex design.
Hammer the square end on to the filler plug. Then insert a large 12 mm Allen key in the hexagon end and turn.
If you don't have such a big Allen key then a hex bit socket and driver will do.
You can use any matching socket and Allen key e.g 10mm socket and 10mm Allen key, I just chose 12mm because it gave a big enough Allen key to put enough torque on to undo the plug.
Post by: rick on March 23, 2014, 03:56:55 PM
What oil should be used?
