For Sale & Wanted => For Sale: => Topic started by: kev126 on February 07, 2014, 09:36:24 PM
Title: 1989 126 bis - SOLD
Post by: kev126 on February 07, 2014, 09:36:24 PM
Fiat 126 BIS
1989
Current Mileage: 28,668
Tax ends: 31st March 2014
MOT ends: September 2014
Contact via PM or 07955374527
Price: £1,400 on alloys + standard wheels + caps
Or: £1,200 on standard steel wheels with original hubcaps
Full picture album >>>HERE<<< (http://s145.photobucket.com/user/Kev-Rosas/library/Fiat%20for%20sale)
_______________
I've owned my 126 since collecting it from Suffolk in October 2012. It has been dry stored since at least 1998, I am unsure of the ten years preceding, but by condition-wise I'd say it's been dry stored it's entire life.
It was undersealed by the first owner upon buying new (so I was told) and is solid underneath EXCEPT for a badly corroded jacking point which I had a garage weld up earlier this week at a cost of £144.00
The car starts on the button everytime even during winter, although I don't drive it much during as I don't like to get it wet! I don't actually NEED a car! It runs perfectly and never skips a beat. I removed the thermostat (All BIS owners recommend it) to prevent it from failing and overheating. It takes a little longer to warm up obviously, however I NEVER drive it until it's warmed up for at least 4-5 minutes.
I orignally planned to take it to the retro show and RRG this year (as I couldn't last year) with it lowered and with wide wheels etc. however I'm now going traveling for at least two years after summer, so not only will I need the money, but there will be no-one to look after and maintain the car.
Since owning, I have:
-Replaced coil (have original one still as a spare)
-Installed Facet SS electronic fuel pump
-Installed Pro-Flow fuel regulator
-Replaced fuel lines with braided ones
-Removed and flushed out fuel tank
-Coolant flush and change with Green Coolant at 50/50 inc. 'Water Wetter'
-Oil change and filter clean
-Replaced alternator belt
-Replaced points
-Replaced condensor
-Rewired ignition wiring from coil etc. with high temp wires
-Replaced vacuum hoses with reinforced ones
-Changed gearbox oil
-Re-sprayed front and rear bumpers
-Bought pressed metal numberplates
-Removed thermostat (will never overheat, I have brand new replacement included in sale, they aren't cheap!)
-Changed spark plugs and HT leads
-Replaced drive shaft rubber boots
-Checked (didn't need adjusting) valve gaps
-Installed re-usable/washable glass fuel filter
-Bought locking fuel cap (original has no lock!)
-Fixed the easher jets which weren't working
I have removed the rear wiper and covered holes with black rubber gromits as it looks ten times better and the rear wiper is absolutely pointless. I still have everything for the new owner to put back if they like.
Still have:
-Original number plates (which were on when I bought)
-Original coil can be used as spare
-Brand new thermostat for anyone who wants to put it back on (I wouldn't)
-Reinforced vacuum hose clipping can be used as spare
-Original Fiat tool kit (rare!) howevere I think a few tools are missing
-Original mechanical fuel pump + push rod (god knows why anyone would want it back on)
-Original fuel cap
I also have a set of brand new unused rear shocks + bushes for older models, which are used as shorter shocks up front on BIS's to get a huge slam on the front, £50 extra if anyone wants! They cost £90 otherwise!
GOOD POINTS-
This car is an absolute wonder to drive, it turns more heads and gets more smiles than my old mega-slammed Renault 5 on wide wheels did! It is one serious head turner and apparently there are only 110 left on the road in the UK. If you can get over the fact the 2cyl 700cc engine is slow uphill, you wont have any complaints! I can get into any parking space and make everyone jealous! Driving it in the sunshine is absolutely amazing especially around Devon when the other classic cars are out and about. It also apparently does 45mpg, not sure how accurate that is but I rarely fill it up.
It's so easy to work on as it's so simple, I myself have learned so much about engines and car workings just from servicing and problem solving on this thing.
I have a load of service history and also the manaul and parts info on a data CD.
Spare set of keys
The refubished (by me, fancied a challege) x19 Bertone 'Phone Dial' alloys have almost new Nankang tyres all round, as does four of the five original steel wheels. Both sets of wheels has a spare.
BAD POINTS-
There is a nick in the seatbelt (nothing major at all, however it was an advisory on MOT)
There is some slight orange rusty bits coming through on a couple of the arches and o/d sill (see pics) and there is a corrosion spot under the windscreen above the vent (see pics, common occurance for these models)
A previous owner has done a pretty crappy job of touching up the paintwork on the bonnet, front panel and scutter pannel under windscreen where I was told kids threw stones at the car! (see pics)
Light corrosion patch on inside of drivers door
The Paintwork isn't amaxing, various scuffs and orange bits coming through but only visable up close
The clip which holds the drivers seat down is missing (never bothered me, but I think it was an advisory)
The front Fiat badge has a crack in it
At the bottom of the boot lid, just underneath some rusty spots are coming through
If anyone is interested, please contact me via PM or ring me on 07955374527 but DON'T leave a voice message as my network doesn't let me access them!
(http://i145.photobucket.com/albums/r216/Kev-Rosas/Fiat%20for%20sale/IMG_2677_zpsba62b56e.jpg)
(http://i145.photobucket.com/albums/r216/Kev-Rosas/Fiat%20for%20sale/IMG_2634_zpse36667b4.jpg)
(http://i145.photobucket.com/albums/r216/Kev-Rosas/Fiat%20for%20sale/IMG_2675_zpse2b66189.jpg)
(http://i145.photobucket.com/albums/r216/Kev-Rosas/Fiat%20for%20sale/IMG_2679_zpscbcfddbd.jpg)
(http://i145.photobucket.com/albums/r216/Kev-Rosas/Fiat%20for%20sale/IMG_2668_zps2b4652f5.jpg)
(http://i145.photobucket.com/albums/r216/Kev-Rosas/Fiat%20for%20sale/IMG_2639_zps345d5b7d.jpg)
(http://i145.photobucket.com/albums/r216/Kev-Rosas/Fiat%20for%20sale/IMG_2660_zps8116ccb1.jpg)
(http://i145.photobucket.com/albums/r216/Kev-Rosas/Fiat%20for%20sale/IMG_2638_zps62b655e4.jpg)
(http://i145.photobucket.com/albums/r216/Kev-Rosas/Fiat%20for%20sale/IMG_2616_zps06083c3b.jpg)
Title: Re: 1989 126 bis FOR SALE - Barnstaple, Devon
Post by: kev126 on February 21, 2014, 04:05:36 PM
Now for sale  :cry:
Post by: DeVilleChris on February 21, 2014, 07:16:10 PM
Good luck with the sale Kev, looks like a really nice car :)
Post by: Kent126 on February 24, 2014, 09:11:50 PM
I really like the alloys on this car
Sent from my iPhone using Tapatalk.
Post by: kev126 on February 25, 2014, 12:48:47 PM
They were painstaking to restore. If the car sells without the alloys then I will be listing them for sale separately.
Post by: poxxxy on February 28, 2014, 12:14:51 AM
Beautiful... tempting to sell my Golf TDI to get this... :D
Post by: kev126 on February 28, 2014, 11:00:58 AM
Thanks  :P I've not had much interest only part ex's which I'm not interested in as I can't have a car while traveling! It's advertised here and retro rides forum, will give it a few weeks before I stick it on the dreaded eBay
Post by: kev126 on March 10, 2014, 12:28:01 PM
Now on ebay
Post by: DeVilleChris on March 10, 2014, 06:33:06 PM
Yeah I saw it go up kev, good luck, hope you get what you're after
Post by: kev126 on March 10, 2014, 06:53:18 PM
Thanks Chris. I've been offered £1000 without the alloys, but with the work and parts I've bought for it I just don't know! I'd be happy with £1,200
I'll keep this updated for anyone interested in the outcome :)
Post by: poxxxy on March 10, 2014, 07:11:29 PM
Yeah I saw it go up to :), if I could land my hands on the cash i'd like it for sure and the alloys really do set it off nice.
Post by: kev126 on March 19, 2014, 01:46:41 PM
68 watchers, 1,200+ views, 0 bids
Had offers of £750, £900 & £1000, and numerous part exchange requests
I can't quite believe no one wanted it!
Post by: poxxxy on March 24, 2014, 12:41:12 AM
Keep her :). Still interested in the alloys though! lol
Post by: kev126 on March 24, 2014, 09:36:38 AM
Sold. The new owners picked her up yesterday morning. Really nice genuine family who will treat her well, that's exactly what I wanted. She'll live for many more years :)
Title: Re: 1989 126 bis - SOLD
Post by: Bar Vitelli on March 24, 2014, 02:29:20 PM
Well done, Kev, hope to see you back soon!   ;)
Post by: kev126 on March 24, 2014, 06:31:32 PM
I'll stay on here and continue to help anyone as I've learnt a thing or two from owning a bis :)
Post by: poxxxy on March 25, 2014, 01:37:42 PM
Were they localish to you or could it appear somewhere else? I imagine you sold with alloys? And for how much ;)...
Hopefully it appears back on here!
Post by: kev126 on March 25, 2014, 02:36:26 PM
The new owners are in Exeter and have joined up to the forum, but whether they start a thread is up to them :)
