Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: essex southend on January 21, 2014, 06:04:53 PM
Title: Plugs, Condenser,Points
Post by: essex southend on January 21, 2014, 06:04:53 PM
Evening all.
Just wanted advice on the above,  what is the best to buy?
Title: Re: Plugs, Condenser,Points
Post by: DEYAN IYI on January 22, 2014, 08:00:51 AM
Plugs NGK standard ones or if you want something better NGK Iridium ;)
A/C standard BP7HS or BPR7HS vs. iridium BPR7HIX
BIS standard BPR6ES vs. iridium BPR6EIX
NB!!! If you run resistor plugs (BPR7HS) do not use spark plug caps with resistor like the original ones. Connect the cable staight to the plug:
(http://www.fiat126vdlaan.nl/catalog/images/bougieverleng.jpg)
It will kill the spark!
Condenser & points - throw them away! There are some topics about.
Regards!
PS - purchase the plugs from a trusted dealer.
Post by: essex southend on January 22, 2014, 10:48:38 AM
Regards!
Thanks for the advice much appreciated
