Fiat 126 Chat => Fiat 126 Chat => Topic started by: DeVilleChris on January 10, 2014, 08:02:15 PM
Hi all, thinking of changing the fuel tank on my DeVille tomorrow. Any advice tips? From people who have done it before?
Thanks in advance
Don't underseal and waxoyl before refitting. I did and it made a grotty job much worse! :D
Hardest bit is getting the fuel filler hose on. I'm not sure what is easiest way to do this...
Keith
I have done this job a number of times and always hated it as getting the filler hose back up in position was always a pain as it is a tight fit in the hole. So last time I had a think about it and ended up squashing the fat top end of the hose and holding it in with a cable tie. Hose went up through the hole easily then I just snipped off the cable tie and completed the assembly ;D
Might be worth checking the fuel sender unit at the same time? I've just ordered one (they are pricey) for Mrs BVs car as the old one was not much more than rust dust.
That sounds like a good approach. I left my hose in the correct position with the tank clamped loosely then wiggled and poked the hose onto the tank spigot. It did work but there is only a small gap to work in and the clip is tricky to get in place.
Keith
Thanks for the tips guys, what sealer do you recommend for sealing outside the tank to prevent water
Be nice to the screws ;D Sometimes (really often) one or more of these 3 tends to break.
Use generously WD40 or something similar. When putting back together, apply a thin layer
of grease or technical vaseline on the studs and use self lock nuts (with the plastic inside).
That's how you'll have them rustfree for the next service interventention in 2034 :P
Thanks for the tips! I changed it last night, my brother and I a good 3 hours because it was the first one I've done but it's a success!!
I've just wrestled my tank back (again). This time, I used Grumpy's excellent tip and I managed to get it back on my own. Much easier than fitting the filler hose with tank in place. A well earned Karma!
Thanks,
Keith
