Fiat 126 Chat => Fiat 126 Chat => Topic started by: chrisrhodesinlbz on December 29, 2013, 09:33:13 PM
Hello Forum members, I hope you all had a good Christmas!
I need a bit of help. I have an 1988 BIS that I've had for 6 years. As far as I know it has never had a radio fitted, but there is a slot where you might expect a radio to go. On the passenger side there is something that looks like it could be a speaker by the passengers left knee (a plastic mounting with holes in it).
I looked into this before and took the car to Halfords about 2 years ago. They were full of confidence in the store, and went out to look, but fiddled around and then gave up!
I'm not expecting the latest technology (ipad/pod compatible etc), but does anyone know how to get a functioning radio in to a BIS where there has never been one before?
Any information very gratefully received!
As far as I know, the wiring should be there for the radio e.g. like the lighter.
Even a modern radio with mp3/iPod inputs can be fitted. They all conform to the DIN standard for size and only require a positive feed, negative earth, permanent live (to keep memory and clock etc) and sometimes an accessory connection. Then you've got the speaker out left and right and front and rear.
Mine doesn't have one either but its a fair way down the 'to do' list! As said, the wiring and physically locating the radio is easy. The tricky one is the speaker location. The left one can go behind the 'speaker' grill but what to do on the right so it looks neat? The doors are skinny so it may be a struggle to get speakers in there. The parcel shelf would be OK but then you lose practicality as it would have to be fixed. I'm thinking the best option would be to mount a pair of speakers beside the rear passenger seat. The recess is deep behind the plastic trim so there should be room. Obviously would be good to know what solutions others have used!
Keith
The wiring is there for the Radio/Cigarette lighter tucked under the dash, You used to be able to buy a R/H speaker pod as was fitted to mine, but it shouldn't be that difficult to make one out of MDF or something ;D
