Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: Pony007fromPL on December 15, 2013, 12:00:51 PM
Title: Polski Fiat 126p for race COMPRESSORE INIEZIONE
Post by: Pony007fromPL on December 15, 2013, 12:00:51 PM
The topic I will be documenting the work:)
I'll start with the engine
The idea evolved from early concepts. The reconstruction changed a lot of times - for example: adaptation of the head with 8 valves DOHC:
(http://naforum.zapodaj.net/thumbs/304a106bc5c6.jpg) (http://naforum.zapodaj.net/304a106bc5c6.jpg.html)
(once for sure I come back to this), the use of the head of the Fiat CC700 to 126p standard engine air-cooled, power supply with two carburetors and many other better or worse ideas. Certainly due to the fact that there were so many ideas , lessons and tests parts put together this together, I have gained a lot of experience .
In brief:
- 2x 34mm Mikuni carburetor (in this engine unnecessary)
(http://naforum.zapodaj.net/thumbs/ae2e74c48c96.jpg) (http://naforum.zapodaj.net/ae2e74c48c96.jpg.html)
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/traby-do-gaznikow,139.html
- Adaptation of the head of CC700 ( head fr use - but with water-cooled cylinders )
(http://naforum.zapodaj.net/thumbs/01c2f3cce249.jpg) (http://naforum.zapodaj.net/01c2f3cce249.jpg.html)
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/glowica-cc700-do-fiata-126p,147.html
-Oil catch tank  ( useful )
(http://naforum.zapodaj.net/thumbs/f77cb79c5e99.jpg) (http://naforum.zapodaj.net/f77cb79c5e99.jpg.html)
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/zbiornik-odmy-mojego-pomyslu,141.html
- Full flow oil filter + cooling ( useful )
(http://naforum.zapodaj.net/thumbs/476be8c1c3be.jpg) (http://naforum.zapodaj.net/476be8c1c3be.jpg.html)
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/przystawka-pelnoprzeplywowego-filtra-oleju-126p,149.html
- Lightened flywheel ( useful )
At the moment is 4.4 kg , is likely to be less
(http://naforum.zapodaj.net/thumbs/60c3d788b2be.jpg) (http://naforum.zapodaj.net/60c3d788b2be.jpg.html)
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/odchudzanie-kola-zamachowego,145.html
- Water pump DIY ( most likely replace it with an electric pump )
(http://naforum.zapodaj.net/thumbs/e06704b52e5a.jpg) (http://naforum.zapodaj.net/e06704b52e5a.jpg.html)
http://www.odrdzewiacz.fora.pl/sport-z-epoki,8/pompa-wody-diy-126p,151.html
So, it was shown how it was done. Later, quite by accident , I discovered that the engine block from the CC700 quite nicely fits into the gearbox ordinary Fiat 126p - when this block is VERTICAL .
(http://naforum.zapodaj.net/thumbs/442b95b9715d.jpg) (http://naforum.zapodaj.net/442b95b9715d.jpg.html)
(http://naforum.zapodaj.net/thumbs/61466aa40479.jpg) (http://naforum.zapodaj.net/61466aa40479.jpg.html)
This engine reminds me of something ...
(http://naforum.zapodaj.net/thumbs/a7226436823a.jpg) (http://naforum.zapodaj.net/a7226436823a.jpg.html) :)
 I'm really liked it , because it looks very nice and retains the character of 126p - engine is the same engine (I mean BIS ) at 126p , only " drenched " another block - so for me it 's not even a swap, but something interesting :) . From what I know , I am the first , which realizes this idea. Well, but the thing - I wanted to use the engine block of CC700 due to hydraulic valves, but I gave up the idea because this solution is not very suitable for sports applications , in addition, requires a number of improvements ( factory defect of these engines is just too soft " glasses " ).
(http://naforum.zapodaj.net/thumbs/1149200d6f77.jpg) (http://naforum.zapodaj.net/1149200d6f77.jpg.html)
(http://naforum.zapodaj.net/thumbs/77e79d399cec.jpg) (http://naforum.zapodaj.net/77e79d399cec.jpg.html)
BUT the BIS engine is haven't got hydraulic valves:). I was able to buy a brand new engine block. Head is from CC700 (bigger valves than BIS), and everything I put on a standard oil pan 126p without air duct.
(http://naforum.zapodaj.net/thumbs/634595b6bafd.jpg) (http://naforum.zapodaj.net/634595b6bafd.jpg.html)
(http://naforum.zapodaj.net/thumbs/77867a90fb9b.jpg) (http://naforum.zapodaj.net/77867a90fb9b.jpg.html)
 Here 's probably a lot of people ask , but what about the water pump and oil (in BIS / CC they are located in the oil pan) . With certain adaptations , the timing of the cover fits into a standard Fiata126p BIS block , and thus fits the oil pump.
(http://naforum.zapodaj.net/thumbs/a737e5cf7488.jpg) (http://naforum.zapodaj.net/a737e5cf7488.jpg.html)
Valve cover is BIS- fit plug & play , of course, to the head of the CC , but in contrast to the CC is steel, so it can be welded to the elements of an ordinary 126p :) because the engine will stand upright.
(http://naforum.zapodaj.net/thumbs/69acfa3822b0.jpg) (http://naforum.zapodaj.net/69acfa3822b0.jpg.html)
(http://naforum.zapodaj.net/thumbs/e2f01b7d27ac.jpg) (http://naforum.zapodaj.net/e2f01b7d27ac.jpg.html)
(http://naforum.zapodaj.net/thumbs/4e01c86fda80.jpg) (http://naforum.zapodaj.net/4e01c86fda80.jpg.html)
(http://naforum.zapodaj.net/thumbs/624465a8c17c.jpg) (http://naforum.zapodaj.net/624465a8c17c.jpg.html)
After sand blasting + already drilled base of the filter.
(http://naforum.zapodaj.net/thumbs/3e33fb7a5b16.jpg) (http://naforum.zapodaj.net/3e33fb7a5b16.jpg.html)
(http://naforum.zapodaj.net/thumbs/9964f775d3a4.jpg) (http://naforum.zapodaj.net/9964f775d3a4.jpg.html)
(http://naforum.zapodaj.net/thumbs/cdd04637d65b.jpg) (http://naforum.zapodaj.net/cdd04637d65b.jpg.html)
I started porting the head
(http://naforum.zapodaj.net/thumbs/4f7a3b7adbec.jpg) (http://naforum.zapodaj.net/4f7a3b7adbec.jpg.html)
(http://naforum.zapodaj.net/thumbs/e828120eb142.jpg) (http://naforum.zapodaj.net/e828120eb142.jpg.html)
(http://naforum.zapodaj.net/thumbs/2c2322055c52.jpg) (http://naforum.zapodaj.net/2c2322055c52.jpg.html)
The next thing - what I wore on the head it was " something of interest " to the engine. I do not like engines forced induction, but I considered the use of a turbocharger. But still, non- turbo is a little hard to tame, is much different phenomena and difficult issues , in addition there is something quite hard to choose. Did a little research and bought a supercharger,  Eaton 24
(http://naforum.zapodaj.net/thumbs/ca20030db7e3.jpg) (http://naforum.zapodaj.net/ca20030db7e3.jpg.html)
(http://naforum.zapodaj.net/thumbs/ae7809908594.jpg) (http://naforum.zapodaj.net/ae7809908594.jpg.html)
Honestly, I chose size on the principle of an eye , and now I know that it will fit me perfectly! Even ( not tested by me) the direction of rotation is correct :) . Well I'm glad! supercharger has always been my dream.  I must design and make the whole intake, compressor and alternator mount - a lot of work .
(http://naforum.zapodaj.net/thumbs/5a6fc5e8c0d5.jpg) (http://naforum.zapodaj.net/5a6fc5e8c0d5.jpg.html)
(http://naforum.zapodaj.net/thumbs/cd528880230a.jpg) (http://naforum.zapodaj.net/cd528880230a.jpg.html)
It's nice that I have a tensioner!
(http://naforum.zapodaj.net/thumbs/e13e7159e314.jpg) (http://naforum.zapodaj.net/e13e7159e314.jpg.html)
(http://naforum.zapodaj.net/thumbs/c8228ac09043.jpg) (http://naforum.zapodaj.net/c8228ac09043.jpg.html)
(http://naforum.zapodaj.net/thumbs/2f4efdcf69e6.jpg) (http://naforum.zapodaj.net/2f4efdcf69e6.jpg.html)
I have prepared a model here:
(http://naforum.zapodaj.net/thumbs/f0d4b3362091.jpg) (http://naforum.zapodaj.net/f0d4b3362091.jpg.html)
(http://naforum.zapodaj.net/thumbs/6ac0bc83deff.jpg) (http://naforum.zapodaj.net/6ac0bc83deff.jpg.html)
(http://naforum.zapodaj.net/thumbs/fabd67158e1a.jpg) (http://naforum.zapodaj.net/fabd67158e1a.jpg.html)
(http://naforum.zapodaj.net/thumbs/b37ec4fea140.jpg) (http://naforum.zapodaj.net/b37ec4fea140.jpg.html)
And here we come to the point where I decided on the construction of the injection - ignition ( with the help of my brother, electronics) with the ability to control boost pressure .
(http://naforum.zapodaj.net/thumbs/0dc78b9c422d.jpg) (http://naforum.zapodaj.net/0dc78b9c422d.jpg.html)
(http://naforum.zapodaj.net/thumbs/6f163bda3039.jpg) (http://naforum.zapodaj.net/6f163bda3039.jpg.html)
(http://naforum.zapodaj.net/thumbs/d132a2cfeae8.jpg) (http://naforum.zapodaj.net/d132a2cfeae8.jpg.html)
(http://naforum.zapodaj.net/thumbs/cd46dbdc8189.jpg) (http://naforum.zapodaj.net/cd46dbdc8189.jpg.html)
(http://naforum.zapodaj.net/thumbs/61a1c8fe27b2.jpg) (http://naforum.zapodaj.net/61a1c8fe27b2.jpg.html)
(http://naforum.zapodaj.net/thumbs/82f7fc85252f.jpg) (http://naforum.zapodaj.net/82f7fc85252f.jpg.html)
I decided to apply the injection of a number of reasons - the most important is to gain experience and knowledge to a greater extent than would result from the traditional system. Another reason is the potential and accuracy of solution - injection, in particular, the MPI can very accurately control the motor and most importantly, to regulate its performance at a specified time (eg data speeds ).The engine very easy to destroy , and I want to have control over it and to learn, gradually improving its performance. Injection , in the initial phase of work and adaptation is complicated , but for example, later to change the settings I don't have to move ( mechanically ) in the system , and also I know a lot more. You can prepare different maps for different purposes , change them accurately and quickly. I want to get close to the limit of my knowledge and continue to learn .
My first attempt with the composite intake manifold - today I have an another idea ( technology )
(http://naforum.zapodaj.net/thumbs/d8bd8c0067a2.jpg) (http://naforum.zapodaj.net/d8bd8c0067a2.jpg.html)
This is a first model of the interior of the "positive" manifold - is wax.
View the lamination :
(http://naforum.zapodaj.net/thumbs/84538c0959e9.jpg) (http://naforum.zapodaj.net/84538c0959e9.jpg.html)
(http://naforum.zapodaj.net/thumbs/c57c44041ee4.jpg) (http://naforum.zapodaj.net/c57c44041ee4.jpg.html)
(it was a prototype , is now working on another )
That brings us to the current moment!
Sheet:
(http://naforum.zapodaj.net/thumbs/c986bfc9c76c.jpg) (http://naforum.zapodaj.net/c986bfc9c76c.jpg.html)
(http://naforum.zapodaj.net/thumbs/f50864f80685.jpg) (http://naforum.zapodaj.net/f50864f80685.jpg.html)
(http://naforum.zapodaj.net/thumbs/82f548725f93.jpg) (http://naforum.zapodaj.net/82f548725f93.jpg.html)
I'm working on a new intake manifold :
(http://naforum.zapodaj.net/thumbs/d4e2a5d2e24a.jpg) (http://naforum.zapodaj.net/d4e2a5d2e24a.jpg.html)
(http://naforum.zapodaj.net/thumbs/bd09c2068e0d.jpg) (http://naforum.zapodaj.net/bd09c2068e0d.jpg.html)
(http://naforum.zapodaj.net/thumbs/fb6ccd429e71.jpg) (http://naforum.zapodaj.net/fb6ccd429e71.jpg.html)
(http://naforum.zapodaj.net/thumbs/80359d08c50c.jpg) (http://naforum.zapodaj.net/80359d08c50c.jpg.html)
I also have an electrically operated relief valve ( by- pass) to the compressor ! New technology!
(http://naforum.zapodaj.net/thumbs/805260e6d950.jpg) (http://naforum.zapodaj.net/805260e6d950.jpg.html)
I finished the model of the manifold:
(http://naforum.zapodaj.net/thumbs/f4285778a6ea.jpg) (http://naforum.zapodaj.net/f4285778a6ea.jpg.html)
(http://naforum.zapodaj.net/thumbs/b1234e8559f6.jpg) (http://naforum.zapodaj.net/b1234e8559f6.jpg.html)
(http://naforum.zapodaj.net/thumbs/4a066a96c642.jpg) (http://naforum.zapodaj.net/4a066a96c642.jpg.html)
(http://naforum.zapodaj.net/thumbs/fc8927ff7fcd.jpg) (http://naforum.zapodaj.net/fc8927ff7fcd.jpg.html)
(http://naforum.zapodaj.net/thumbs/04fd340f5423.jpg) (http://naforum.zapodaj.net/04fd340f5423.jpg.html)
(http://naforum.zapodaj.net/thumbs/ff3239c48e58.jpg) (http://naforum.zapodaj.net/ff3239c48e58.jpg.html)
Now it looks:
(http://naforum.zapodaj.net/thumbs/8ded9657b2db.jpg) (http://naforum.zapodaj.net/8ded9657b2db.jpg.html)
Greetings!
Title: Re: Polski Fiat 126p for race COMPRESSORE INIEZIONE
Post by: Wagoneer on December 15, 2013, 06:40:42 PM
Wow Pony, that's an amazing build so far, I'm looking forward to more.
Post by: Pete126 on December 15, 2013, 06:52:09 PM
Fantastic Build so far :thumbup Thanks for sharing keep us updated on your progress :)
Post by: r20vt on December 15, 2013, 07:13:42 PM
bravo dear friend for your progress
you love to doing this!!
 :D :D
Post by: Pony007fromPL on December 15, 2013, 08:57:35 PM
Thanks 4all!
I corrected the links in the first post! Check this :D
That's what I write is understandable for you ?
Post by: DEYAN IYI on December 15, 2013, 11:51:58 PM
 :o :good: "Like"
Waiting for the song of the engine!!! 8)
What about the cam shaft, will it be modified?
Thanks for the fun!
Post by: Pony007fromPL on December 16, 2013, 02:32:13 PM
I don't know what cam shaft yet :$ Something little faster then production:)
Post by: DEYAN IYI on December 16, 2013, 04:34:07 PM
About perfect for supercharging is the 650E one. You don't need something like 290 or 300*
Check this out!  :) http://victorylibrary.com/supercharger/super-engine5.htm
My second project is also with a blower, but for now I got only Aisin AMR 300 and Dellorto DHLA 40, so I need another 126 ;D
Kind regards! I'm very happy to follow both supercharger projects on the forum!
Post by: Pony007fromPL on December 18, 2013, 08:06:09 PM
Last parts to injection:
(http://naforum.zapodaj.net/thumbs/259abf9015e6.jpg) (http://naforum.zapodaj.net/259abf9015e6.jpg.html)
(boost pressure sensor, air valve)
Oil pan modify:
(http://naforum.zapodaj.net/thumbs/0084fe485172.jpg) (http://naforum.zapodaj.net/0084fe485172.jpg.html)
(http://naforum.zapodaj.net/thumbs/50b047ee9ebc.jpg) (http://naforum.zapodaj.net/50b047ee9ebc.jpg.html)
(before)
(http://naforum.zapodaj.net/thumbs/0b0002e7873b.jpg) (http://naforum.zapodaj.net/0b0002e7873b.jpg.html)
Great place for oil dipstick!
(http://naforum.zapodaj.net/thumbs/684e414926c0.jpg) (http://naforum.zapodaj.net/684e414926c0.jpg.html)
Post by: Pony007fromPL on December 22, 2013, 11:23:58 AM
Supercharger (airbox) & alternator mounting
(http://naforum.zapodaj.net/thumbs/186c7d40e9e4.jpg) (http://naforum.zapodaj.net/186c7d40e9e4.jpg.html)
(http://naforum.zapodaj.net/thumbs/0c313397ea84.jpg) (http://naforum.zapodaj.net/0c313397ea84.jpg.html)
(http://naforum.zapodaj.net/thumbs/6eb51cbf6691.jpg) (http://naforum.zapodaj.net/6eb51cbf6691.jpg.html)
(http://naforum.zapodaj.net/thumbs/8c568e7a7e84.jpg) (http://naforum.zapodaj.net/8c568e7a7e84.jpg.html)
Oil pan:
(http://naforum.zapodaj.net/thumbs/3cc6761b652f.jpg) (http://naforum.zapodaj.net/3cc6761b652f.jpg.html)
Post by: pietschokkenbroek on December 22, 2013, 03:10:42 PM
WOW!!  :o really impressive  :thumbup please keep us posted!!
Post by: Pony007fromPL on January 02, 2014, 05:22:48 PM
(http://naforum.zapodaj.net/thumbs/b45b3933b0ac.jpg) (http://naforum.zapodaj.net/b45b3933b0ac.jpg.html)
(http://naforum.zapodaj.net/thumbs/c2695b5e5dca.jpg) (http://naforum.zapodaj.net/c2695b5e5dca.jpg.html)
(http://naforum.zapodaj.net/thumbs/c50de14a0584.jpg) (http://naforum.zapodaj.net/c50de14a0584.jpg.html)
(http://naforum.zapodaj.net/thumbs/b25c6f27c6ff.jpg) (http://naforum.zapodaj.net/b25c6f27c6ff.jpg.html)
(http://naforum.zapodaj.net/thumbs/05420a928972.jpg) (http://naforum.zapodaj.net/05420a928972.jpg.html)
(http://naforum.zapodaj.net/thumbs/c926d14dc4c8.jpg) (http://naforum.zapodaj.net/c926d14dc4c8.jpg.html)
Post by: Pete126 on January 03, 2014, 07:31:44 PM
That's Sweet Man :thumbup Well Done :good:
Post by: grubscrew on January 18, 2014, 07:42:50 PM
 Nice work, very very nice. Mike.
Post by: Pony007fromPL on February 05, 2014, 06:17:34 PM
My engine gallery (like it! :) ):
https://www.facebook.com/media/set/?set=a.538729222889066.1073741831.453274184767904&type=1
(http://naforum.zapodaj.net/thumbs/722f987b7da4.jpg) (http://naforum.zapodaj.net/722f987b7da4.jpg.html)
(http://naforum.zapodaj.net/thumbs/71fe2c816bbe.jpg) (http://naforum.zapodaj.net/71fe2c816bbe.jpg.html)
(http://naforum.zapodaj.net/thumbs/3fffc05e848d.jpg) (http://naforum.zapodaj.net/3fffc05e848d.jpg.html)
Sorry for photos quality!
Con rods from Fiat 1050ccm! It's fits almost perfect (they are 2mm longer then 126p)
(http://naforum.zapodaj.net/thumbs/1df44ba34947.jpg)
(http://naforum.zapodaj.net/thumbs/c431a8e62408.jpg)
(http://naforum.zapodaj.net/thumbs/949ef4888ae9.jpg)
Comparison:
(http://naforum.zapodaj.net/thumbs/d4ea28cad3cb.jpg)
In this month I don't have a lot of time for engine:(
BUT! See idea for mounts exhaust MIVV
(http://naforum.zapodaj.net/thumbs/a89071611f39.jpg)[/url]
(http://naforum.zapodaj.net/thumbs/686d11fb6fea.jpg)[/url]
MIVV - to repair:
(http://naforum.zapodaj.net/thumbs/39a2d55859f0.jpg)[/url]
http://www.odrdzewiacz.fora.pl/blacha-karoseria-nadwozie,4/naprawa-tlumika-motocyklowego-kosmetyka,204.html
The inscription will be engraved
(http://naforum.zapodaj.net/thumbs/facc1defa94a.jpg)[/url]
(http://naforum.zapodaj.net/thumbs/c721eb509eb1.jpg)[/url]
(http://naforum.zapodaj.net/thumbs/4e0ab2ce2056.jpg)[/url]
Post by: Pony007fromPL on February 17, 2014, 07:32:24 PM
(http://naforum.zapodaj.net/thumbs/f925d6f6ed11.jpg) (http://naforum.zapodaj.net/f925d6f6ed11.jpg.html)
(http://naforum.zapodaj.net/thumbs/b11cb10814cf.jpg) (http://naforum.zapodaj.net/b11cb10814cf.jpg.html)
(http://naforum.zapodaj.net/thumbs/b396549fd007.jpg) (http://naforum.zapodaj.net/b396549fd007.jpg.html)
(http://naforum.zapodaj.net/thumbs/4efaadbfa295.jpg) (http://naforum.zapodaj.net/4efaadbfa295.jpg.html)
(http://naforum.zapodaj.net/thumbs/1d39e2fef9d4.jpg) (http://naforum.zapodaj.net/1d39e2fef9d4.jpg.html)
(http://naforum.zapodaj.net/thumbs/1fdf8cad02d1.jpg) (http://naforum.zapodaj.net/1fdf8cad02d1.jpg.html)
Post by: Pony007fromPL on March 15, 2014, 10:56:40 AM
(http://naforum.zapodaj.net/thumbs/0368ed7cba57.jpg) (http://naforum.zapodaj.net/0368ed7cba57.jpg.html)
(http://naforum.zapodaj.net/thumbs/831435a23bcb.jpg) (http://naforum.zapodaj.net/831435a23bcb.jpg.html)
(http://naforum.zapodaj.net/thumbs/4b4e35197cfc.jpg) (http://naforum.zapodaj.net/4b4e35197cfc.jpg.html)
(http://naforum.zapodaj.net/thumbs/20a48f8a44c9.jpg) (http://naforum.zapodaj.net/20a48f8a44c9.jpg.html)
(http://naforum.zapodaj.net/thumbs/442075f85711.jpg) (http://naforum.zapodaj.net/442075f85711.jpg.html)
(http://naforum.zapodaj.net/thumbs/5af103c12d1c.jpg) (http://naforum.zapodaj.net/5af103c12d1c.jpg.html)
(http://naforum.zapodaj.net/thumbs/72be59b6bab8.jpg) (http://naforum.zapodaj.net/72be59b6bab8.jpg.html)
(http://naforum.zapodaj.net/thumbs/d22a3a6d1855.jpg) (http://naforum.zapodaj.net/d22a3a6d1855.jpg.html)
(http://naforum.zapodaj.net/thumbs/e3a22ee3a588.jpg) (http://naforum.zapodaj.net/e3a22ee3a588.jpg.html)
(http://naforum.zapodaj.net/thumbs/bb84e958b6e9.jpg) (http://naforum.zapodaj.net/bb84e958b6e9.jpg.html)
(http://naforum.zapodaj.net/thumbs/d9397a56bea5.jpg) (http://naforum.zapodaj.net/d9397a56bea5.jpg.html)
(http://naforum.zapodaj.net/thumbs/d2d55c92e783.jpg) (http://naforum.zapodaj.net/d2d55c92e783.jpg.html)
(http://naforum.zapodaj.net/thumbs/99a20d2cc1cc.jpg) (http://naforum.zapodaj.net/99a20d2cc1cc.jpg.html)
(http://naforum.zapodaj.net/thumbs/5b39fb5c6198.jpg) (http://naforum.zapodaj.net/5b39fb5c6198.jpg.html)
(http://naforum.zapodaj.net/thumbs/5641b0b31c9e.jpg) (http://naforum.zapodaj.net/5641b0b31c9e.jpg.html)
(http://naforum.zapodaj.net/thumbs/76ba03cca633.jpg) (http://naforum.zapodaj.net/76ba03cca633.jpg.html)
(http://naforum.zapodaj.net/thumbs/f31938c145a1.jpg) (http://naforum.zapodaj.net/f31938c145a1.jpg.html)
(http://naforum.zapodaj.net/thumbs/7c3321995326.jpg) (http://naforum.zapodaj.net/7c3321995326.jpg.html)
(http://naforum.zapodaj.net/thumbs/f2703c196887.jpg) (http://naforum.zapodaj.net/f2703c196887.jpg.html)
(http://naforum.zapodaj.net/thumbs/e1199ef75ed1.jpg) (http://naforum.zapodaj.net/e1199ef75ed1.jpg.html)
(http://naforum.zapodaj.net/thumbs/9fd0545ce14e.jpg) (http://naforum.zapodaj.net/9fd0545ce14e.jpg.html)
https://www.youtube.com/watch?v=d__z8aOtm7U&feature=youtu.be
www.facebook.com/126pcompressoreiniezione
Post by: pietschokkenbroek on March 16, 2014, 01:38:15 PM
Work of art!!  :good:
Post by: gammakeith on March 16, 2014, 06:29:40 PM
Wow!  I wish I could weld like that.  That engine is looking something rather special and I'm looking forward to seeing it completed.  Mind you, it looks like you forgot to install the crankshaft  :P
Keith
Post by: Kowalski on March 16, 2014, 07:25:39 PM
Very interesting!
Looking forward to seeing it finished (with its crankshaft  :D)
cheers,
Andre
Post by: Pete126 on March 16, 2014, 09:19:51 PM
Wish you were nearer, fantastic fabrication :thumbup
Post by: Pony007fromPL on April 15, 2014, 08:30:54 PM
Thanks for comments:)
News:
(http://naforum.zapodaj.net/thumbs/a3fba67b1bfb.jpg) (http://"http://naforum.zapodaj.net/a3fba67b1bfb.jpg.html")(http://naforum.zapodaj.net/thumbs/ad0bfc6f7a7b.jpg) (http://"http://naforum.zapodaj.net/ad0bfc6f7a7b.jpg.html")
Post by: poxxxy on July 05, 2014, 12:18:48 AM
I am in love! Such beautiful work :)
Post by: pony007 on September 28, 2014, 08:54:35 PM
Some new parts:
(http://naforum.zapodaj.net/thumbs/3d7c3ee265d9.jpg)
Head:
(http://naforum.zapodaj.net/thumbs/b794234db012.jpg)
(http://naforum.zapodaj.net/thumbs/f5c9e535eb09.jpg)
My modyfication:
(http://naforum.zapodaj.net/thumbs/0c203af0a307.jpg)
(http://naforum.zapodaj.net/thumbs/8da40709bfae.jpg)
(http://naforum.zapodaj.net/thumbs/3fb27b83713d.jpg)
(http://naforum.zapodaj.net/thumbs/88a74dce6dc5.jpg)
(http://naforum.zapodaj.net/thumbs/9d87805e96b8.jpg)
(http://naforum.zapodaj.net/thumbs/1d8b283d6bfc.jpg)
(http://naforum.zapodaj.net/thumbs/35dbf080f9d0.jpg)
whole head needs porting
Water pump PAD Bosch:
(http://naforum.zapodaj.net/thumbs/9058698c823f.jpg)
Some fitting
(http://naforum.zapodaj.net/thumbs/a94130d6c981.jpg)
(http://naforum.zapodaj.net/thumbs/5a44a1201f60.jpg)
Post by: andyzeetec on September 29, 2014, 12:39:07 PM
Looking good! :good:
Post by: poxxxy on September 29, 2014, 10:41:53 PM
Looks great :D. Still amazed at all your DIY equipment and quality of the product in the end too!
Post by: Mics126 on October 01, 2014, 08:54:44 PM
It looks good, will be great to see it running.
Mike
Post by: Bolek on October 03, 2014, 12:09:24 AM
"zajebiste"  :D
Post by: pony007 on October 08, 2014, 09:28:33 PM
Piston rings- Prima Poland
(http://naforum.zapodaj.net/thumbs/7732992d876b.jpg) (http://naforum.zapodaj.net/7732992d876b.jpg.html)
(http://naforum.zapodaj.net/thumbs/70561d1682fc.jpg) (http://naforum.zapodaj.net/70561d1682fc.jpg.html)
(http://naforum.zapodaj.net/thumbs/d85b05cb7cf4.jpg) (http://naforum.zapodaj.net/d85b05cb7cf4.jpg.html)
Supercharger leak repairs...
(http://naforum.zapodaj.net/thumbs/4b58a3dbb83a.jpg) (http://naforum.zapodaj.net/4b58a3dbb83a.jpg.html)
(http://naforum.zapodaj.net/thumbs/eec4e31f53e9.jpg) (http://naforum.zapodaj.net/eec4e31f53e9.jpg.html)
(http://naforum.zapodaj.net/thumbs/d2e15a952b92.jpg) (http://naforum.zapodaj.net/d2e15a952b92.jpg.html)
Bed oil.
(http://naforum.zapodaj.net/thumbs/8880c0e1d217.jpg) (http://naforum.zapodaj.net/8880c0e1d217.jpg.html)
(http://naforum.zapodaj.net/thumbs/f1252c10fb21.jpg) (http://naforum.zapodaj.net/f1252c10fb21.jpg.html)
(http://naforum.zapodaj.net/thumbs/29b040a2e5a7.jpg) (http://naforum.zapodaj.net/29b040a2e5a7.jpg.html)
(http://naforum.zapodaj.net/thumbs/533df561db40.jpg) (http://naforum.zapodaj.net/533df561db40.jpg.html)
(http://naforum.zapodaj.net/thumbs/cda121536c83.jpg) (http://naforum.zapodaj.net/cda121536c83.jpg.html)
Post by: gammakeith on October 09, 2014, 06:54:14 PM
oooooooh!  More shiny bits  :P   Its just getting better and better!
Keith
