Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: jolly500 on November 18, 2013, 04:17:35 PM
Title: Push rod tubes
Post by: jolly500 on November 18, 2013, 04:17:35 PM
I've got a 650cc motor with a skimmed head and am having a problem with the push rod tubes - the seals (thin type) seem to be pushing out at the bottom. I suppose logically the 'concertina' type would be better for my application as the compressibility should allow a better fit. Or maybe those fancy aluminium ones with the spring!
Anyone have any comments?
Steve
Title: Re: Push rod tubes
Post by: Rusty's Uncle on November 18, 2013, 04:43:32 PM
I thought that the solid tubes use the much deeper seals to take up the slack so if you have solid tubes & thin seals and they are being forced out then that sounds not good. I just happen to have some used concertina type tubes to hand and they measure 16cms shoulder to shoulder when not under load if that helps  :)
