Fiat 126 Chat => Fiat 126 Chat => Topic started by: gammakeith on November 14, 2013, 06:30:13 PM
Title: BIS Overheating
Post by: gammakeith on November 14, 2013, 06:30:13 PM
Dear all,
I would appreciate some advice on the BIS cooling system in general.  I know the engines are prone to overheat and blow head gaskets but I'm not familiar with the weak points.  Basically, I was wondering if this was a problem when the cars were new or only becomes an issue as components age?  The previous owner clearly struggled with overheating.  He fitted a top mounted thermostat and a manual over-ride switch.  I have traced an intermittent loss of cooling fan function to a badly corroded connector in the passenger footwell and the relay connectors near the fuse box don't look too brilliant either.  Given that the fan takes getting on for 10 amps on full power then I'm probably going to run a fresh fused feed from the battery and rewire as appropriate.  However, if the standard fan switch kicks in at too high a temp then its not going to be much better.  Thus, I was wondering if its worth splashing out on something like this;
http://www.ebay.co.uk/itm/321171673655?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Its a lot of money but that would plumb in nicely into the top hose and I could then leave the original wiring in place as a backup? The downside would be that I could only run the fan on a single speed. Alternatively, I could use this which has two temp switches (both lower than BIS standard) but they are not adjustable;
http://www.ebay.co.uk/itm/390589750908?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
I'm certainly going to flush the rad and pipework and check the thermostat.   Any advice from the experts on how they have dealt with keeping the car cool would be much appreciated.
Thanks,
Keith
Title: Re: BIS Overheating
Post by: Hazey-n-Marc on November 14, 2013, 06:55:42 PM
You need to bleed the heater matrix as well, it is easy to overlook. I have only had overheating issues due to airlocks or running too lean, luckily my cooling fan has always cut in and saved the day.
Post by: gammakeith on November 14, 2013, 07:39:10 PM
OK, that's something I hadn't considered.   Is there a bleed point or is it a case of loosening the upper hose to get the air out?
Its good to hear you have had few problems.  My engine is running a cone filter and does seem to be running a little lean so perhaps I had better look at that as well.
Thanks,
Keith
Post by: Rusty's Uncle on November 14, 2013, 08:05:53 PM
I bought a brand new Bis in 1989 which blew the head gasket after about 2 years. It is not an age thing , more a design fault but of course it was denied by Fiat at the time. Fortunately now the problem has been identified there are fixes. One day you guys will be able to keep up with the aircoolers  ;D
Post by: Hazey-n-Marc on November 14, 2013, 09:19:08 PM
There is a bleed pipe screwed to the top of the heater unit cover under the bonnet on the drivers side just in front of the scuttle, just look for a clearish pipe with a turny thing in the end.
There is a diagram in the subscriber section that shows it, go to fiat 126 bis full workshop manual factory, Ancillary components, 2nd page.
Post by: Amateb8 on November 14, 2013, 09:27:03 PM
I have had my Bis for a couple of years now, and knock on wood, it has not overheated. I do keep an eye on the cooling fan, making sure it switches on automatically. It is, I think a two speed fan. It does short bursts at low speed, but it really comes to play when the temp reaches half way. I do not wait for the light in the dash to light up. I top up the system once and a while using a 50/50 battery water and Halfords coolant mix. I also flush the system once every two years. I've kept my thermostat in the original format. I keep a watchful eye on the temp gauge. I don't know, but I think changing the oil every year helps.
I agree with Rusty. Having spoken to a Fiat veteran who still works in the parts department at my local Fiat dealer. He was delighted to see my Bis. He mentioned that Fiat was inundated with warranty claims re overheating from the early models. He mentioned the early 1987 watercooled versions were problematic, but were all rectified. Though he said, Fiat sorted the overheating problems from 1988 Bis models onwards.
Post by: Hazey-n-Marc on November 14, 2013, 09:30:21 PM
Early 87? I thought that the very first BIS engine came off the line in September 87. I assume mine is an early one as it was registered 6 months after the first was made.
Post by: Amateb8 on November 14, 2013, 09:33:31 PM
Yeah, I was going to say to the chap, I thought the UK had the Bis from 1988 onwards. Perhaps they sold the Bis in Poland from 1987, and reached our shores sometime in 1988.
Post by: gammakeith on November 15, 2013, 07:33:32 AM
Thanks for all the feedback.  So it does seem that the car was prone to overheat from new.  Thus, I'm seriously tempted to fit the adjustable fan switch to get the fan kicking in earlier.  However, I'll tidy the wiring first, then drain the system so I can remove and check the existing fan switch.  I'm not convinced its working so it would be good to test for peace of mind.
The fan circuitry on the car seems a bit daft.  The low fan speed is triggered by the fan switch tripping the main fan relay which in turn earths the (permanently live) fan via the fan resistor.  What is really odd is that the high fan speed is triggered by the fan switch directly earthing the fan and bypassing the resistor.  That means the higher temp contacts in the fan switch have to switch nearly 10 amps.  That seems a really bad piece of design!  Why on "earth" did Fiat not do it the other way around or fit twin relays?  I normally dislike changing what a manufacturer has done (they normally know best) but in this case the system just seems ripe for improvement.
Keith
Post by: chrisrhodesinlbz on November 18, 2013, 10:03:40 PM
This is very non-technical I know, but I have a 1988 BIS with no conversions of that type.
If it is a hot day and it is slow-moving traffic with the needle pointing anyway near towards the red bit, I just put the heater fan on to full (ie the second setting), slide the heater control to the 'full red' setting and open all the windows (which let's face it is fairly easy, even if you are on your own) and the temperature gauge goes down quite quickly.
My fan only seems to noticeably go on when I park the car up, when it roars. This must be a design fault. I had a BIS user guide which I bought from ebay, which someone must have nicked when I did not lock the car (it prob went back on ebay) and I think that suggested the same method.
I have not got round to the conversion, yet in the 5 years I've had my BIS, it seems to work for me....so far!
Post by: gammakeith on November 19, 2013, 10:11:09 AM
The previous owner of mine also used the heater fan to cool the car down. The heater matrix in a car is usually fairly small so that suggests that simply getting the radiator fan to kick in earlier should do the trick.  I have just bought a new BIS fan switch and am going to carefully check the activation temps before it gets fitted to the car.  I am going to see what that corresponds to on the temperature gauge.  If (as I suspect) its too high then I will source an alternative that will kick in at a more appropriate temp.
The fan kicking in after you stop is consistent with the set point being too high.  Basically, when you stop the engine, the heat from the engine has to dissipate into the cooling system so the cooling system temperature will keep going up for a little while even though the engine is off.
Keith
Post by: gammakeith on November 19, 2013, 05:38:15 PM
OK. I've just tested both sets of contacts on a brand new (Commercial Ignition XEFS83) fan switch using an accurate thermocouple.  I gradually raised the temperature and recorded the temp at which each switch closed and then let the temp gradually fall until the switches opened.  Repeated twice and results were as follows;
Low speed (Black/White wires): On at 99.0/98.5, Off at 90.4/89.7  (Manual states on at 96-100, off at 90-94)
High speed: (Red/White wires): On at 99.0/98.5, Off at 90.0/89.7 (Manual states on at 101-105, off at 90-95)
Thus, the low speed contacts are within spec whilst the high speed contacts are not.  As near as I can determine both sets of contacts are switching at exactly the same point so that's not much use :cry: I accept the results would likely be different for each brand of switch but I think the low speed trigger specification in the manual (96-100 degrees) is too high for comfort.  Thus, I will modify and report back in due course  ;D
Keith
Post by: Amateb8 on November 21, 2013, 10:06:22 PM
My one has probably got a different setting. I have yet to hear the fan switch on after I've parked the car. The low speed fan switches on for just 2 seconds every couple of minutes when the needle is about a quarter. The high speed fan switches on as soon as the temp dial hits the middle every few minutes for about 5 seconds. So far there is no need to switch on the heater as the temp gauge never go beyond the middle section, but occasionally, as a precaution I do also switch on the heater, but not all the way.
I find that on long journeys, it is worth stopping for about half an hour or so. The engine seem to recover quite nicely, and the temp also improves, sometimes seating less than half.
Post by: gammakeith on November 22, 2013, 07:19:15 AM
Thats interesting and suggests there is a lot of variation here.  My wife was worried about overheating the car yesterday as it was getting close to the red so she stopped and let it cool off for a while.  At no time did the fan kick it.  The wiring is all working so it must be the rad sensor.  Bless, she had forgotten I had fixed the manual over-ride for the fan  ;D
I now have ordered an alternative switch with lower "kick in" settings.  That will be wired in with a fresh fused feed and twin relays.  I'm hoping that works...........
Keith
Post by: chrisrhodesinlbz on November 22, 2013, 11:06:50 PM
Hello
This has been really interesting for me. I have read for years on the Forum about the BIS overheating and have probably worried/become oversensitive about it. Perhaps I've spent too many years reading the 126 Forum problems and anticipating them!
My BIS generally only goes over 2/3rds on the very hottest Summer days with slow-moving traffic - that's when I use the 'heater method' and notice the fan going on when I stop.
I read somewhere once about moving the thermostat to the top of the engine, with a 'kit'. Does anyone have experience of this? and where I could get it? or is that the same as the items mentioned in gammakeiths post?
Thanks!
Post by: 1973/126 on November 23, 2013, 09:10:43 AM
 Ricambio used to the kits for the bis, but they don`t seem to sell them anymore.
 I think Pete126 has one of them installed on his car.
Post by: gammakeith on November 23, 2013, 09:40:09 AM
I have that "raised thermostat" kit on my car as well.  However, at the end of the day, if the fan switch trips in too late its going to overheat (like mine).  I've just got the following;
http://www.ebay.co.uk/itm/390589750908?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I measured it as tripping in at 85 degrees on the first contacts and 90 degrees on the second contacts which strikes me as a little more sensible than the original (or the other ebay one I tried).  The actual switch has the same thread as the original so would screw straight into the rad but, alas, Googling the part number on the switch did not get any hits.
Two of these;
http://www.ebay.co.uk/itm/400292899718?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
and one of these;
http://www.ebay.co.uk/itm/190836949737?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Plus some soldering should get it sorted quite nicely  :)
Keith
Post by: chrisrhodesinlbz on November 24, 2013, 10:38:59 PM
Thanks very much for your explanations and advice!! This Forum always comes up trumps.
I'll look in to getting that fix done!
Post by: gammakeith on November 25, 2013, 07:20:32 AM
You might want to wait until my 'fix' is tried first!!  I might be reporting back that my fan is now running for 75% of the time and the car is running too cool  ;D
Keith
Post by: gammakeith on December 01, 2013, 07:03:33 PM
Well so far so good!  I spent a fair bit of yesterday rewiring so I'm now the only bits of the original fan wiring I am using are the two live feeds for the fan and idle solenoid.  Even then I had to bypass the two rusty connectors in the passenger footwell and cut back a fair way to find good copper to solder the repair sections in.  The original idle solenoid was also rusted solid internally but fortunately I had a spare that worked fine.  The two new earth relays and the shiny new resistor are now mounted to the left of the air-box.   I ended up just swapping the old fan switch for the new one as I was worried about over-cooling if I plumbed the new switch into the top hose as originally planned.  I think that was the right call as the fan kicks in on the low speed setting at about 1/3 of the way along the gauge.  Even though it was close to freezing outside my wife reported she had to turn the heating down as it was getting too hot on full.  The fan ran on for 10-20 sec after the ignition was turned off (spirited drive) so it looks like its about right to me!  I measured the low speed switch on the new fan switch as kicking in at 85 degrees which is approx 10-15 degrees lower than the specification for the original.
Looks like that's one job ticked off the list  ;D
Keith
Post by: Pete126 on December 01, 2013, 07:29:50 PM
Good work Keith :thumbup
Post by: Scarlettkitten on December 01, 2013, 08:32:51 PM
Nice one, I've got this to do on my BIS as someone has had a go and it doesn't look like the fan kicks in :( may take me a while as car electrics scare me :o
Post by: gammakeith on December 02, 2013, 12:28:32 PM
First checks are simple.  Disconnect the two connectors from the radiator switch (bottom far corner) and bridge the white (earth) and black pins to check low speed operation (if I remember the colours correct) then bridge the white and red pins to check high speed operation.  I suspect (like mine did) the high speed fan will run but not the low speed.  The low speed circuitry is much more complex as it relies on a relay at the front working and a good connection to the fan resistor.  You should also get the idle solenoid clicking when you activate the low speed circuit.  The fan takes a lot of current so connections must be good!!
Keith
Post by: Scarlettkitten on December 02, 2013, 06:01:47 PM
Yep you were right, hi works but not low, so I'm going to fit the same as you did I think :) Cheers for the help.
Post by: gammakeith on December 03, 2013, 07:18:57 AM
Does your fan relay click when your bridge white/black?  If so, its worth checking the connections to the low speed resistor at the bottom of the fan housing.  Its in an excellent position for getting blasted by road muck/salt etc.  My connections were in a bit of a state. Otherwise, it could be the relay itself.  I was it that position not long ago and finding corroded connections everywhere drove my decision to rewire the circuit.  While I was at it, it seemed sensible to put the extra relay for the high speed earth so I can use an alternative fan switch with lower trip-in.......
Keith
Post by: Scarlettkitten on December 03, 2013, 03:13:04 PM
No click when i bridge wht and blk, someone's had a bodge session in there, twisted wires and insulation tape everywhere, I'll just redo it and bin the hacked wiring I think, it's a real mess.
