Fiat 126 Chat => Fiat 126 Chat => Topic started by: Amateb8 on October 25, 2013, 08:09:46 PM
My baby failed its MoT due to brake lights not working. The mechanic replaced the brake switch saying it was defective. He replaced the switch, but the brake lights still would not work. Worryingly, he tried to find the cause, as clearly there was power going into the switch, but no brake lights. He checked the fuse, then he literally unearthed the wiring loom (checked each connector from fuse box to rear tail lights), so the interior was partly removed, trying to find whether there is a break in the system. To cut the story short, several hours later (i.e. MoT booking was at 8:30am, finished at 5:30pm), it turned out that the socket that plugged into the circuit board in the brake light housing was dirty. As soon as he cleaned it, the brake lights worked! It made me think perhaps the old brake light switch was still operable. He was a bit embarrassed.
Amazingly, the indicator lights in the dashboard now works perfectly (the indicator light used to sort of lightly blink, if at all) with a clear ticking sound when turning left/right! I managed to negotiate a deal on the labour charge, as it seems it was an error. Unfortunately, the Italian chap that usually deal with my Fiat's MoT was off that day.
All's well that ends well. ;D
:-X
The usual test for a defective brake light switch is to just connect the two wires on the switch. If the brake lights then work it confirms that it is the switch at fault.
It's a bit late now, but may be a useful tip for someone else with a brake light problem.
Unfortunately garages generally take a guess then replace something instead of doing any sort of diagnostic work. Pete is spot on with how to check it. At least it's sorted now. :D :D :D :D :D :wave
