Fiat 126 Chat => Fiat 126 Chat => Topic started by: the duke of 126 on October 07, 2013, 04:31:56 PM
I just was looking on ebay and there is a listing for a acuspark elec ing for the bis . Anyone tried one ?
It won't fit unless you drill and tap holes in the BIS points plates. They are listed for a BIS but don't fit! There's a few threads hanging around. Stick to the points
ok , so as I suspected the electronic ignition did not fit , kev126 was right.
I had phoned to check before I purchased it and was told "no it fits the bis perfectly."
it was listed as suitable for the bis
it turned up and I could see it would not work before I even tried to fit.
anyhow I rang them and spoke to the owner and arranged to call in at their unit as its at Basildon and I was going past there on my way to lakeside.
the guy was really helpful . he sorted me out another bit of kit that he said was ok for the bis
its basically a little box the size of a matchbox that you fit . it has 4 wires.
1. coil + 2. coil - 3. ground/bodywork 4. distributor
just fit in engine bay and plug as above . it stops the points being used , it just uses them as a 12v switch, the points gap is no longer important as they are either on or off.
the kit is so easy to fit and the bis wire from the coil even has the right connection on just under the engine lid cover (follow it back) so basically all you do is disconnect the original distributor wire (leave it in the case under the lid rim so it does not short out) and connect the other wires as above.
I was dubious , but hey ho , it works a treat ,it has a little led light that lights up when the thing is working. seems to start better and runs a treat . I will try and post a picture. bellow
it is not fitted as such , just in position to see if it worked, I will fit properly later . when it is working you can leave the cover off the dizzy and see the points no longer sparking.
he reckons you will never have to change them again , he also gave me a sensor to fit inside the dizzy to sense the rotor position so I can remove the points totally , I have not got round to this yet.
https://www.dropbox.com/s/os73dfquc5dl8e5/2013-10-13%2018.23.19.jpg
all I can say is , is this an answer to bis electronic ignition ?
Is it to be found on ebay?
I bought a new , kit from Beaulieu Autojumble for £25.00, its still in its box, but due to fit it soon. Mike.
Mine was item number 120848644005, if there is none listed , email the seller , but make sure they send the one for the bis , not the one in the picture
