Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: Bruce on March 26, 2006, 07:45:43 PM
If i fit CC Sporting wheels with 155/65 tyres do i need spacers behind the wheels or do they just fit straight on?
cheers
Just found out that when fitted to the CC the wheels had spacers, i have seen quite a few 126s with these wheels fitted, so they will fit but does anybody know if they need the spacers and if so, what thickness should i be looking to purchase?
cheers.
you dont need spacers chuck them straight on
cheers bis that is fantasic news, and i believe you have 165/55s on yours, do they foul the arches when you turn the front wheels to full lock? although i will more than likely be going for 155/65s because they are almost half the price.
no fouling ,nothing and i am a fat b/stard who corners like a nutter
um might go for the 165/55s then, anybody know what these Nankang tyres are like, they are certainly well priced, and they are even rated for susstained speeds of up to 130 mph so i'll be allright to take my bis on the autobahns :)
Must be a commom fault bis13 with 126 owner's I suffer the same thing.Love doin it past anally retentive BMW owner's
well i should be able to beat you guys in a race then!!! Not through skill but through weight! :lol: :lol: im a skinny runt. :lol: :lol:
probably will Chris, another fattie here :)
yeah but i have no hair...
niether do i
well go my wheels fitted along with 4 new Nankang 164/55 13s, great fit and they look pretty cool aswell. ended up using the original Bis wheel bolts as the cinquecento ones that came with the wheels have a different thread, my spare was bald so i picked up an unused siecento space saver for less than the cost of a new standard 126 tyres, which is almost identical to the standard bis wheels yet is painted red with a big yellow blob with 80 in it; does this mean if i put this red wheel on the car i can get it to do 80 :) mind you with the alloys and Nankang tyres it should be good for 130 as that is what it say the tyres will do.
nice one bruce,always good to fit new wheels.
by the way,if anyone does need them,i think a local parts center still has some spacer sets to fit 126 etc,you see them here first before i ebay them,if they are still there,(they were in 1982) :cool:
mine has 175/60/13 (mini size) thes dont rub at all ... until I lower it
stuey,funny thing is.......mine rubbed more before i lowered it......center line of wheel is now well in the well!...lowering kit is WELL recomended,as mentioned before,push hard through (tight) corners and the car does not lift and tuck in(outer rear to the corner),its great...it does show its limits by lifting an inside rear and spinning it..more so now with the engine mods......and in the wet its very easy to power slide it through the same corner.......... :cool:
what are the spacers for and how thick? certainly do not need then with the wheel tyre combo i have the wheels are on the limit as it is, any wider and the arches would need to be modified, or are they the sort that were quite common in the 70/80s and were used to space out standard wheels instead of fitting wide wheels/tyres, i used to have some on my Robin before i got hold of some super slots for it, i think they used to be all the rage on minis back then. i believe they were very good at wrecking wheel bearing by realy messing up the wheel/hub offset
you got it,i think they are paddy hopkirk or something like that......used to have them on moggy minors etc...they are NOS items.......i'll stick them on ebay
just think what they would do to your king pins!!!!!!!!!!
guys i have a brain teaser for you, i bought some late 13£ x1/9 alloys the 3 poke style ones off ebay, they have 165 / 70 tyres on there what tyres would i have to have on to be able to get them on my aircooled trouble free? are they painted? and will they polish up nicely without repainting?
Mick youve got 165 / 55 13's??
(http://www.fiat126.co.uk/images/Tyres0031.jpg)
not as nice as you cromos dave
would appreciate any help
I used to have an X1/9 with those wheels a few years ago, the wheels are painted (as are virtually all modern alloys), you may be able to clean them if not there are companies that can refurbish them but this costs, if you have the centres these are not painted (or they shouldn't be). there are 3 tyre sizes that you could use that are close enough so as to not change the gearing or speedo reading by enough to make any difference, they are 145/65, 155/60 or 165/55. the first is a bit narrow for those wheels but would fit, the midle size is a common size fitted to many small cars such as the matiz, the later is a performace tyre only made by a 2 tyre makers but it looks great on the 126
Thanks Bruce thats helped me alot so best go for 165/55?
Bis13 (Mick) has these on his cinq alloys, so these will fit my cromos ok?
thanks again m8
I've also got em on my cinq alloys, on my otherwise stock bis. I'll post pickies when i get some taken
here they are on the wee beastie:
(http://www.bruces-stuff.pwp.blueyonder.co.uk/my%20Bis.jpg)
