Fiat 126 Chat => Fiat 126 Chat => Topic started by: gason on March 25, 2013, 11:03:12 PM
Title: help starting up
Post by: gason on March 25, 2013, 11:03:12 PM
Hi all just want to know where I am going wrong , My 126 AC starts on the button all I do is pull the choke up full , pull the starter and off she goes. The problem is if I touch the gas it cuts out straight away, When i get into the car at first i do not touch anything. It is like it is trying to warm up and refuses to move until a few minutes has passed.
Title: Re: help starting up
Post by: JonW126 on March 25, 2013, 11:45:54 PM
At least yours starts..... Mine won't !
 :cry:
Post by: gason on March 26, 2013, 12:26:02 AM
Sorry to hear that Jon maybe remove the plugs and put a drop of petrol in just to get it to fire, warm the plugs might help
Post by: 1973/126 on March 26, 2013, 06:51:35 AM
 I would check the carb for leaks. Make sure the seals and the plastic spacer under the carb  are all in good condition and properly tightened.
Post by: JonW126 on March 26, 2013, 07:57:08 AM
I need lessons as I'm new to this, hopefully have a mechanic coming round this weekend to give me some pointers.
Post by: Draigflag on March 28, 2013, 07:26:07 PM
Thought id post here rather than new topic! Just been to get the paint code off mine, thought id see if she starts. Ignition came on, as did interior lights, but engine wont even turn over, not even a click?! Any ideas? Last time I used her, I cleaned the engine. Is there anything that might have got water in it to stop it turning over? Or is the batt just flat?
Post by: JonW126 on March 29, 2013, 06:01:41 PM
YAY..... Mine is running, been out today for almost 2 hours getting used to her.... Love it. Love it. Love it.  :D
Post by: gason on March 30, 2013, 09:56:51 PM
nice one I thought you got it for the wife  ;D. I was out in mine today runs fine every time i stop I think it is going to cut out but it never does , but a bit nerve racking when you pull up at a major junction and you cannot hear if the engine is still running  :o
Post by: Hazey-n-Marc on March 31, 2013, 10:04:44 AM
If the interior lights go dim when you turn the key then you have a flat battery. If the lights don't change it will be a dodgy electrical connection or relay.
Marc
Post by: gason on March 31, 2013, 12:07:21 PM
I noticed I got what sounded like my first back fire when dropping the gears in a hurry and stopping
Post by: dajwid on March 31, 2013, 03:18:29 PM
Timing
Post by: gason on March 31, 2013, 05:53:10 PM
Been out for a spin and 3 times it cut out when i stopped. The choke appears to be the only thing that keeps it ticking over at a comfortable level , like its not going to cut out. Very nerve racking as it stopped at 2 junctions and I had to push it  :o
Post by: 1973/126 on March 31, 2013, 06:57:50 PM
 You can turn up the idle by a screw on the carb. Adjust it when the engine is fully warmed up.
Post by: Draigflag on March 31, 2013, 09:40:24 PM
Got mine started too. Think it was a flat battery, even though id tried using jump leads twice, I think the battery on my Abarth was low too.
Post by: gason on April 01, 2013, 12:35:44 PM
Yesterday was the first maiden voyage with only 3 breakdowns ,The car may start first time from cold with the choke up full but cuts out if you touch the gas at all , I noticed a back fire once also, I will try giving the grub screw a quarter turn in or out I dont know  :o
Post by: Lloyd74 on April 02, 2013, 11:03:08 PM
give that carb some love, the fact that the choke needs to be on suggests a lean mix perhaps the jets need replacing or at least cleaning (not by physical means which may cause damage but using carb cleaner), also check the timing,not familiar with the ac carb but it may be a flat spot between the pilot jet which it runs on when at tickover and the main jet which it runs on when the throttle is opened so when you blip the throttle it cuts out as the main is not providing enough fuel at that point as needle too low? Like I said not familiar with the ac carb but is just a general carb principal observation! Be mindfull that the original timing settings will be for leaded fuel and not modern fuel which has a different burn rate and optimum ignition point. Set it to standard and then raise the tickover and move the distributor untill a consistant even exhaust note is found (consistant running bum bum bum bum not bum bum bot bum bum bot),back down the revs and repeat moving the dizzy either way will result in faltering you have to move it either way to find the optimum point and then lock it off! Multiple consistant Bum Bum is good ! find the Bum Bum!
Good Luck Llllllloyd
