Fiat 126 Chat => Fiat 126 Chat => Topic started by: markbubble on February 17, 2013, 08:03:35 PM
hi guys,having trouble with the fuel on my dads bis that e just bought,there is no or very very little of fuel getting to carb,,iv removed pipe from carb to fuel pump turned over and nothing but a drip if im lucky, removed the 2 pipes to tank and after blowing down them it turns out one pipe is split (think its the return pipe) does this meen the tank isnt getting pressure enough to send fuel to carb?
i persume the tank needs removing to replace the pipes(while its off will give good clean and paint etc) does the tank simply come down with the 3 bolts removed?
cheers in advance mark
Hi Mark, I removed my tank with the help of a friend a couple of months ago as a pipe had become disconnected from the top of the tank.
The tank is held on with three bolts and then you'll have to disconnect the filler and breather pipes too. We had it high up on a set of ramps and even then it was an absolute ball-ache to do.
I suggest you flush the tank, clean up the fuel sender connection, replace the fuel pipes/clamps and place a fuel filter before the fuel pump. You will not want to have to remove the tank again, trust me!
We ( Stuey (cheers) and myself) changed mine with just a trolley jack (halfords I think.) The only problem we had was getting the breather and filler back on. You should be able to replace the send return pipes without removing the tank completely, but as Kev says, it will need at least flushing to not keep blocking up all of the time, I put a brand new tank on, it only cost £21. If you remove the passenger side trim below the window (the door card not on a door, it (allegedly, we only found out about this after doing my tank!) it gives better access to the pipes on the tank.
Marc
I removed the trim in the back as well, to find it offered no help and was a waste of my time! It must vary on different cars? Clipping the filler back onto the tank was the hardest part too
What's the handiest way to remove that panel? I had a quick look on Saturday but didn't go any further.
If I remember right... Take out the seat bench, take off the seatbelt bolt and just pu the trim off as it's held on with clips
The plastic plugs that hold the panel in place will almost always shear off so be carefull how much pressure you put on the panel in case it splits. Lubricate & be gentle with the little nuts that hold the sender in place. You can slide the mesh filter off from the end of the pickup tube if you wish then fit an online filter downstream of the fuel pump so you can manage any muck in the petrol without taking out the tank in future. Refitting the tank is a pain in the butt if you are working on your own but last time I did it I got a cable tie , crimped in the top of the filler hose by hand then put on the cable tie. The filler hose then passed up through the body shell easily :)
cheers for the help guys,i want to remove and clean the area under (or sould i say above!) it anyway and give tank good clean out and paint etc,where did that new tank come from at that price ?as it might be best fitting one for that money i will fit another filter in before pump as sugested thanks
mark
axle Gerstle, last year, think they have gone up a bit, but not loads.
Ok, they have gone up by quite a lot
http://webshop.fiat500126.com/index.php/katalog/artikelinfo/521-1-fuel_tank.html
Or 126 fan, cheaper.
http://www.126fan.sk/eshop/index.php?main_page=product_info&cPath=7&products_id=435
You ought to get the sender unit gasket as well, forgot myself, luckily it came off fine.
Marc
cheers marc,thats still good price ,il see how good or bad tank is when i remove it!
mark
