Welcome to the CLUB126UK Forum => Introduce Yourself => Topic started by: markbubble on February 08, 2013, 07:43:15 PM
Title: hi all new 126 bis owner here
Post by: markbubble on February 08, 2013, 07:43:15 PM
hi all,im the new owner of a 92 126bis in hull,been sat for around 10 years so needs a good check over on all parts and good service! needs a small amount of welding to windscreenbottom corners but otherwise very solid! bonnet is bad so on lookout for another at some point ! hopefull this weekend il get started on checking brakes,steering etc and get a list of parts i need!
cheers mark
Title: Re: hi all new 126 bis owner here
Post by: Pete 126bis on February 08, 2013, 08:05:13 PM
 Hi and welcome , we are all friendly and helpful on here so please ask even if its the smallest , stupidest question you should get a comment wether good or bad  ;) . I have had the same problem on the windscreen bottoms and didnt worry about it just took my time ,slowly cut out bad metal and in stages put new in and very pleased with results ,will put some pictures up if i get chance , we all like to see pictures  :) best of luck Pete
Post by: Pete126 on February 08, 2013, 09:15:59 PM
Hi Mark, not too far away from me :welcome to the Forum/Club126
Post by: Amateb8 on February 08, 2013, 11:39:04 PM
Hello and welcome to the forum!!
Post by: markbubble on February 09, 2013, 08:39:47 AM
thanks for the warm welcome folks :) iv done a few restos in my time mainly bikes,scooters and bubble cars as well as a little fiat 900e van so the little fiat sould be fun,i cant see any major nastys on the car but who knows what il find once start working on it (havnt decided if its a he or she yet!) the car will be mainly used by my parents as a run around and to get my dad doing someting now he is retired :) i persume the engine comes out easy like most little fiats iv worked on so was going to remove it to give a good clean,flush of coolant and oil and service etc any tips/advice would be most welcome,iv heard the head gasket can be a problem on the bis,is it worth taking head off while engine is out to do valves and new gasket etc ?
cheers mark  8)
