Fiat 126 Chat => Fiat 126 Chat => Topic started by: guy2yourleft on December 12, 2012, 04:24:53 PM
Title: Latest purchase
Post by: guy2yourleft on December 12, 2012, 04:24:53 PM
My 652cc is in multiple pieces strewn about in my garage (for my 500) and my pleas have been finally heard by my wife who finally saw the aforementioned "mess." I purchased a Haynes Manual!!! last night from the UK Amazon and it might take a couple weeks to get it, but it should be here by New Years.
After tearing into the motor as much as I have, I'm thinking the oil pump cavitated. Also, the piston rods are quite loose on my crank, which I'm willing to bet is not good either. Any other inputs for this malady would be appreciated if someone has run into this before.
My wife, bless her heart, suggested I should take my 126's engine out and put it in the 500 so we can sell it quicker.  :o I stopped laughing about an hour later...
Title: Re: Latest purchase
Post by: dajwid on December 12, 2012, 05:27:15 PM
All the manuals are on this site to view/download  :D
Post by: Rusty's Uncle on December 12, 2012, 05:42:39 PM
Pump cavitation is generaly caused by a very worn pump, a restricted / blocked inlet or a pump trying to pump too heavy a media. The manual should give you the tolerances for the pump wear. The 652ccs engines have a higher volume oil pump than the 499 engines , the whole timing chain cover assembly is interchangeable.
Capitulation as opposed to cavitation is when you have to give in to the wife  :$ ;D :$
Post by: guy2yourleft on December 12, 2012, 06:27:32 PM
Capitulation is more than likely where this is heading.  :cry:
As an aircraft hydraulics technician, I shouldn't have a problem with the pump.  I'll also probably wind up giving it a good rebuild whether she needs it or not. When my engine gave out, there was a loud clang, wouldn't start again, and it had been running for about a hundred miles at 100-ish kmph. It wasn't until later I read on this site about giving the engine time to cool down and it makes sense. It gets nice and toasty back there and the oil continues to keep thinning or burning off until (my guess) the pump cavitates or siezes, resulting in ungood sounds and vehicular operations at 0% capacity.
Then again, my condenser could have simply gone bad.  :P
Are the loose piston rods on the crankshaft something to worry about?
Post by: grubscrew on December 12, 2012, 07:45:24 PM
Loose as in end floatie across the journal or up and down on it?
Post by: Rusty's Uncle on December 12, 2012, 07:45:56 PM
Inspecting the pump is quite easy but two of the four M10 hex head screws are hard to get a socket or ring spanner on so you have to dismantle the pump drive if you can't free it off with an open ender. If you refit the pump with socket head screws then it can be removed as a unit.
There is some side clearance at the big ends so the con rods will move from side to side but best to whip off an endcap and check out the shells and the crank bearing surface. A new set of shells are only about £20 in the UK and probably much cheaper with the 126 fan guys.
As for oil I now run fully synth 10/60 , expensive but so is an engine rebuild . I read that it is "more robust" at the higher temperatures that the air cooled engines run at  :)
Served me well today as I was flat out on the M25.
Post by: Hazey-n-Marc on December 12, 2012, 07:55:32 PM
[/quote]
Those 50 mph average speed cameras do have their uses.  :D
Post by: guy2yourleft on December 12, 2012, 08:19:48 PM
barely any movement up and down, more of a fore and aft or side to side motion across the journal.  I measured the front piston rod at 1/4 inch travel. Back rod came in under a 1/16th, quite minimal.
Post by: Rusty's Uncle on December 12, 2012, 09:02:35 PM
[/quote]
It was a short burst as part of a 50 mile run getting on the slip road at Hunton Bridge , think it is junction 19 , then it is all uphill for a long stretch before a short downslope to junction 18. I know from my GPS that the speed is correct and I have hit a true 70 mph on that uphill stretch which cant be bad for a standard engine  ;D
Post by: Hazey-n-Marc on December 12, 2012, 09:31:55 PM
I have had over 70 according to the speedo across the fens, bit of a tail wind and a very amused transit driver behind me though.
