Fiat 126 Chat => Fiat 126 Chat => Topic started by: Tim on March 03, 2006, 10:50:19 PM
Title: Welding
Post by: Tim on March 03, 2006, 10:50:19 PM
On Monday my little car is going under the torch for corroded rear inner sills. I know very little about welding but when the man quoted for the job he reckoned a lot of preparation would be in order. Hence the high price. (Yes he did suck air in through his teeth while looking at it).
I've noticed that you can by new inner sils and inner sil rear panels. Is he likely to mean he needs to make these things? Or is he just talking about cutting bits out do you think?  Everything else under the car appears solid.
I suppose what I really need to know is, am I likely to be better off, or get a better repair, if I ask him to use new sils?  Or will it make no difference.
Tim
P.s. On a different but related topic, how hard is it to fit a replacement lower windscreen panel? Obviously the screen will have to come out (preparation (sigh)), but with new sills and this panel fitted my car will be in practically mint condition!
Title: Welding
Post by: Darkhorse on March 04, 2006, 04:50:18 PM
Hi there,
Firstly on the subject of inner sills and repair sections you didn't state how much you were quoted but the panels are available and I would strongly suggest using the complete articles.
As for the widscreen scuttle panel I have never seen one of these available! if you can get hold of one then thats great if not then repair panels would need to be fabricated up and the windscreen does need removal for this job
On a whole if your doing all the floor repairs then while its off the road it makes sense to do the scuttle too.
