Fiat 126 Chat => Fiat 126 Chat => Topic started by: Tim on February 27, 2006, 10:49:55 PM
Title: Useful tips, info + warnings for new BIS owners...
Post by: Tim on February 27, 2006, 10:49:55 PM
....wanted.
I just bought a beautiful little car on ebay (item 4615595530) and already am  both thrilled and slightly worried.
I had to drive it home 70 miles including long dull streches of Motorway.  How hot should the engine run? My needle flirted with the red zone all along the M20 and for most of the M25. It seemed ready to overheat practically all the time I was in forth (accept going down hill).  Even when I tried slowing down to 55 it still insisted on running hot.
But; when I came off the motorway and dropped into third it immeadiately started to cool.  Back into fourth along a bendy country road and it was heating up again...
Is this normal? Can it be stopped inexpensively? I am aware that head gaskets blow often on these cars but I see no sign of that having happened.
I always thought cars got hot standing still and cooled at speed. Was I wrong?
Advice please.  I can tell one end of a spanner from the other but am not a mechanic.  I can also tell one end of a biro from the other, that doesn't make me a writter....rambling now....Are there any more surprises in store?
P.s. Do I need a spare wheel for an MOT?  If so what size should it be?
 [/b]
Post by: Chris Lakin on February 27, 2006, 11:24:12 PM
hi there Tim congrats on your buy!!!!
firstly im worried about the needle going into the red, it should never get that hot!!!! it should always be at half way point / below. Check the car has enough water, top it up with antifreeze!
as you already know that BIS's fatal flaw is the headgasket, my theory is this is completly down to the thermostat, which gets blocked from the limescale deposits and crud, which build up from the water and aluminium alloy engine reacting so keep a good antifreeze with corrosion inhibitor in.
before you run the car again, GET A NEW THERMOSTAT in!!!(which is cheap) if this one is blocked up you will warp the engine + headgasket will go, you are lucky it didnt go the other day!
Conversion kits are available which relocated the thermostat to the top where the head is, from the badly located point near the sump.
were you getting good heat from the heater? if so, this means there is no airlock in the cooling system! which is good news. Also by running the heater it draws the heat from the engine.
when you refered "I always thought cars got hot standing still and cooled at speed. Was I wrong?" this may have occured on the aircooled models, but the BIS is continualy being cooled.
i hope this helps m8, i wouldnt run her too much at the mo, check out the thermostat and get a new one in ASAP, its really easy to do, i will and im sure the other will help guide you through if you have any probs. Have you got a workshop manual yet? You get a free BIS CD manual when you join the club.
Title: Re: Useful tips, info + warnings for new BIS owners...
Post by: ChrisRLewis on February 27, 2006, 11:28:58 PM
Quote from: "Tim"
P.s. Do I need a spare wheel for an MOT?  If so what size should it be?[/b]
The spare wheel is not one of the checks for the MOT, so no problem in not having one! Not sure on the wheel/tyre size perhaps someone else can help?
Post by: 126cab on February 28, 2006, 08:55:42 AM
Hi Tim yes same as chris says get that thermostat changed and flush the engine & radiator, and if you do go for the convesion kit (which again is easy to fit) that should stop any futher problems. Dont forget to bleed the heater when refilling ie red tap under bonnet at drivers side of heater
Post by: Tim on February 28, 2006, 11:18:31 AM
Thanks for the info guys.  It already has the thermostat conversion so no worries there but I will certainly try flushing it.
But how come it runs at normal temperatures around town and stationary.  Wouldn't a faulty thermostat make it run hot all the time? :???:
Tim
P.s. Is there a decent maintanence schedule on line?
Post by: 126cab on February 28, 2006, 03:36:56 PM
Hi Tim, sounds like your timing check the advance and retard is working ok and not stuck also check timing. with a strobe if possible. Also check carbs not running weak. It could also be your radiator thats partly blocked as its ok when stationary and round town ect but when you give it a bit of work to do it starts to get hot. perhaps it could be a bit of all three mentioned.
Post by: Tim on February 28, 2006, 09:58:49 PM
Timing sounds a likely culprit.  I've just noticed it runs on a bit after I've switched the ignition off.  Am going for MOT tomorrow (wish me luck) so may well get it checked at the garage as I don't have a strobe or much free time at the moment.
Thanks.
Post by: maxlee on March 01, 2006, 01:32:49 AM
yep look in to the timming flush the system through to make sure the fan is coming on and the switch that switchs it on is clean.
1st thing you want to do now you got it home is clean the oil filter out and change the oil oil changes might have beeen done but i bet the filter has never been tuched
also it dont hurt to change the gear box oil
there should be some pics some were of the oil filter and were it is on the engine chriss you still got them laying about???
Post by: paul harbinson. on March 01, 2006, 07:41:06 AM
Hi Tim,another quick check is when the car is warm,feel the top radiator hose firstly to see if it's hot and second to see if it's rock hard.This can be sympton's of two thing's,one an air lock in the system or a blocked radiator. :wink:
Post by: Tim on March 03, 2006, 03:11:12 PM
Hi guys,
Thanks again for all the advice.  Have suffered a minor set back at MOT, but nothing large(ish) sums of hard-earned cash shouldn't solve (sigh).
Two failure points; front wheels foul arches on full lock (tyres too wide) and... diguised by a layer of filler and underseal, extremely corroded inner sils  :sad:
It was horrible! I watched the tester bashing away with his little hammer and kept hoping I could see bits of dry mud falling off.  Worse yet, when he showed me what he'd found you could just about see where someone had marked up the areas requiring work so the seller must have known. :evil:
I bought the car off ebay and asked all the right questions too! 'Minor surface rust' he lied; 'Very solid underneath, nothing to worry about' he said....b*******!
Anyway, have booked in to a decent local garage for repair and they promise to check the timing for me while they're at it. I will then tackle the 'minor surface rust' next week.  Anyone know the paint code for a white BIS?
Tim
Post by: Chris Lakin on March 03, 2006, 03:46:36 PM
hi there tim
sorry to hear about that, get it sorted properly and it will put your mind at ease! Its just a minor set back, so is it going to be welded up? You get alot of disshonest people, but had the owner had it long?
ok the colour for the white BIS (cofu blanca) i think its called is 244 but....
in halfords i bought the spray can listed 244 which is on the paint details sticker under front bonet, but it was too yellowy more like the colour for the "meteor ivoy" bis aka primrose as its been called somtimes. I left it for a couple of years, but went bk recently and had a look through the colours at halfords again, hoping i would find a decent match i eventualy found a white code:233 which is a perfect match!!! ive used it on mine it & looks exact. I will double check this 233, im 99% sure thats the code for this one from halfords. I will check the can when i get in for you.
Post by: gregs656 on March 03, 2006, 06:53:19 PM
hmm thats a shame.
However, get the work done properly and at least that way you will know exactly whats going on with your car.
good luck
Post by: paul harbinson. on March 06, 2006, 07:49:55 AM
That's a shame Tim.The mot's boys' over here are not aloud to go prodding for rust.They have a special tool and are only aloud to apply certain pressure.If it dos'nt give way it's ok.
Post by: fiatfsm on March 06, 2006, 01:06:24 PM
over here, if a tester suspects rust he can tap it with a special tool they have, its a very small hammer! Paint code is 233 on the aircooled FSMs so I reckon thats what you need.
Post by: Chris Lakin on March 06, 2006, 06:53:32 PM
Barry on the BIS, paint code in front bonet its stated as 244 (like on mine)
but in halfords it the correct colour is 233.
Post by: Tim on March 11, 2006, 07:09:55 PM
All sorted!
Garage have done a neat job of welding the inner sills.  New thermostat has cured over-heating problem. New fuel filter has solved regular breakdown problem + have cleaned up contacts in headlamp switch so the rear lights work too.  Stuck fuel filler cap removed, destroyed and replaced.
Happy days
Post by: Chris Lakin on March 11, 2006, 11:17:31 PM
excellent tim!! i bet your pleased.  :lol:
i had a feeling, it was thermostat casuing fluctuating tempretures.
My BIS had been in our garage for 6 years before I had the head gasket done, so it had been sat there soaked in water/oil.
When i removed the thermostat housing, it was clogged up with what looked like porridge. (deposits from where the water had reacted with the alloy engine and caused corrosion)
I always say the most reliable 126's (especialy the BIS) are the ones which have been run regularly.
i would flush your coolant out and replace with new antifreeze with corrosion inhibitor make sure this is present. (50/50 mix)
