Fiat 126 Chat => Fiat 126 Chat => Topic started by: Kipster on May 31, 2012, 08:33:35 PM
Just had a look at my new style V5 cert.
I have noticed that the car is now registered as 11/12 1973. On the old V5 which i no longer have it was 11/2/1973.
Not happy about this, can i do anything?
Ideas please.
Have you tried doing the DVLA vehicle enquiry search to show what's actually showing?
It may be just a typo?
Yes, it shows 11/12/73, which i know is different from the origiinal.
Thanks.
I've just checked my old records (quite sad but I did some research on 1973 models some months ago) and your car O** ***M was registered on 11/12/1973 when I checked at the time...
Thinking about it I believe the first 1973 models were registered in June 1973 (mine is August 1973) so I think 11/12/1973 will be the correct date.
Hope that helps.
I think there were some L reg 126s. The only way to find out would be to get a dating letter from Fiat, or just compare your VIN number with Bar Viittelli and this would give you an idea if it`s possible that your car was registered 11/02/73. It might have been a miss print the first time.
There were definitely L plate 126's but I think they were demonstrators. Will try to find the pictures again.
Hope that helps.
Thanks for that.
Must be a senile figment of my imagination :cry:.
Put my mind at rest.
Found it!!!! L plate 126. In the august 1973 edition of autocar.
http://www.flickr.com/photos/triggerscarstuff/4928164436/in/set-72157624684116697
Just noticed the blue one on the front page is a L plate as well ::)
