Fiat 126 Chat => Fiat 126 Chat => Topic started by: Lina on May 04, 2012, 03:28:38 PM
Title: On Fire!
Post by: Lina on May 04, 2012, 03:28:38 PM
Literally.
Just leapt from the car and had the fire brigade called with their nee-naws on my way home from work...
Fire was out by the time they got there and I was VERY lucky as there's little damage I can see apart from the fuel pipe that caused it, the red hose to the rocker cover is a bit melted and some other rubber stuff.
Pretty shaken and not sure what this means for getting to Brooklands tomorrow morning...
Ironically, it was the old fuel pipe left that caused it - as the firemen said, the rest has been replaced with new pipe and clips.
I need a vodka.
Title: Re: On Fire!
Post by: Hazey-n-Marc on May 04, 2012, 04:08:33 PM
 :yikes :yikes Probably what has been causing your running problems.
Glad you are ok, hopefully the car is not too bad as well.
Good job it was out by the time they got there, they would have doused it and cracked the block.
Title: Re: On Fire!
Post by: 1973/126 on May 04, 2012, 04:29:28 PM
 Never a dull moment with these cars :o.
 I`m glad you are O.K.!!! and that it ended reasonably well. I remember a video of a 126 on the IOW which has caught fire and completely burned down :cry:
Title: Re: On Fire!
Post by: Bar Vitelli on May 04, 2012, 05:35:11 PM
Oh dear, that sounds scary...
Glad that you are okay, vodka does sound like a good idea, hope you get your car back on the road soon, if not for Brooklands then at least for Retro Rides!
Title: Re: On Fire!
Post by: nrg19uk on May 04, 2012, 06:04:25 PM
Glad your ok!!!
a perfect time to remind people the importance of carrying a fire extinguisher.
Title: Re: On Fire!
Post by: Hazey-n-Marc on May 04, 2012, 06:06:47 PM
And checking all old fuel lines.
Title: Re: On Fire!
Post by: Lina on May 04, 2012, 07:03:19 PM
Well, it's all rather surreal now... got towed home, checked it all over and it's not too bad (again, VERY lucky!)
As I had the new fuel line and clips already, just waiting to get fitted this eve ready for Brooklands tomorrow, I just went ahead and fitted the new line...and it's all working well again!!
I've just finished cleaning it and (cautiously) filling it up with petrol and it's now weirdly sitting outside my house, working and looking all innocent as if nothing's happened!!!
I keep having to check the boot lid for the scorch marks to believe it all happened!
Weird.
Thanks for all your comments - hopefully I'm brave enough to attempt Brooklands tomorrow a.m.!
Title: Re: On Fire!
Post by: Hazey-n-Marc on May 04, 2012, 07:31:43 PM
Don't let it stop you. You know what caused it, you have sorted it. Just remember your wellies.
Title: Re: On Fire!
Post by: Amateb8 on May 04, 2012, 11:08:44 PM
Great to hear that you are okay!
Title: Re: On Fire!
Post by: bis13 on May 05, 2012, 09:14:04 AM
its vital that the fuel lines cannot flap about or be able to rub or overly flex as they will eventually fail, be very cautious and always carry a fire extinguisher in the car, it is a car/life saver. on the plus side its good that you are unscathed and the car has got of with minor injuries do not be put off by this as all cars have the risk of fire in the engine bay the good point about our car is its so simple that the fire can be easily located and attacked!
