Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: Funkin Go-nut on December 01, 2011, 10:48:49 PM
Title: A/C Air intake and air filter
Post by: Funkin Go-nut on December 01, 2011, 10:48:49 PM
Is the air intake from the cooling fan on an A/C restricted or does the fan act a bit like a supercharger?
I was wondering if replacing the piping with a cone filter would give any benefit, especially as it would suck in warm air from the engine bay?
Title: Re: A/C Air intake and air filter
Post by: gsxr126 on December 02, 2011, 04:12:30 AM
Apparently, you can get up to 1/2 a pound boost.
Post by: thepuddlejumper on December 02, 2011, 12:57:51 PM
An old Italian friend told me to drill 8mm holes in the bottom of the air filter holder to allow additional air pressure through, he said it was a turbo effect, he used to tune 500's for the track. I never did it so I can't comment on how successful it would be.
Post by: DEYAN IYI on December 02, 2011, 01:26:10 PM
No, it's not working like supercharger. And it doesn't suck hot air. The accelerated air, that goes to the filter, could be even a bit colder than the surrounding one, if the hot tins don't spoil it.
There are polish rationalizations like this http://www.126fan.pl/www/dolot.htm. My logic says (if ti really makes boost) that it can only disturb the action of the carb, cos it's not a blow-through type.  But drilling some holes will let the air to reach easier the filter.
What is your idea? Soft tuning or just to make it a bit better?
The cone filter itself wont give any notable result. Better make also resonator intake "strumenica" in polish, and lift up 20mm the carb. These 3 things will prove the power about the maximum power on 4500 and will let the engine to rev easier to the max rpm of about 5500.
The original exhaust is a crap, so you need to find a sport one or even better DIY  http://denior.prv.pl/ click "Tlumik do kaszlaka..." It gave +2,5hp on dyno and -15% fuel consumption on 80km/h ;)
Well, this is it ;) But you better think about real carb, if you want to feel the power :P
Regards!
Post by: Rusty's Uncle on December 02, 2011, 02:01:34 PM
Interesting little topic, I think that someone posted some pictures a while back showing a ring of holes through the base of the air filter housing to give a little turbo effect. That air filter / top of the tinware section always reminds me of something that was designed by a long gone committee and I am sure there are reasons for the design but it is the same design used on the 126 as almost the earliest Fiat 500s. Just dug one out of my garage for a close inspection and the design looks quite crazy to me with a restricting plate that has a fairly small opening at the end of the inner air feed section. Air can leak into the twin walled air filter section where the top cover clips go plus there is a single plain hole for some reason top nearside.
Generally the tin ware leaks air like crazy at the joints so perhaps with a bit of more effective sealing if a little pressure could be diverted then could be interesting.
Please somebody tell me that this just will not work otherwise that is another damn thing to experiment with  ::)
Post by: bis13 on December 02, 2011, 08:30:53 PM
i did have an engine that had gaskets that fitted between the tin and stopped air leaking out but they were rubber and very sticky and way past their sell by date so i binned them, perhaps looking at making some might be a winter project....obsession...
Post by: nrg19uk on December 02, 2011, 09:34:10 PM
a dose of clear silicon when bolting the tin work together ?
Post by: Funkin Go-nut on December 02, 2011, 09:48:00 PM
I must admit I thought it had been designed so that the intake had positive pressure, but I wasn't sure.
The engine was designed by some ferrari bloke wasn't it? Would he have thought to use the fan driven air do you think?
I guess the reason the tuners remove this airfilter and housing part is beacuase the intake would be restrictive for a larger/more sporty carb, and more air is diverted for cooling?
If the intake could be modified I can't see why it wouldn't add a ram air/low pressure turbo type effect if everything was sealed and the intake opened up a bit...
 :headscratch:
Post by: gsxr126 on December 03, 2011, 12:01:21 AM
Start experimenting Rusty ;)
Went to visit the fiat specialist in Sydney and he got talking about boost from the cooling fan. He explained exactly how he did it but I cant remember what he said :- except that he got 1/2 pound boost
I will be visiting over the next week, so I'll get him to 'please explain' again & try to get some photos.
Deyan, I think its all about making the air fuel mixture go into the combustion chamber a bit more efficiently, rather than disturbing the carb action. It offers very very modest performance gains, but increases fuel economy.
