Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Milky on January 24, 2006, 08:31:46 PM
Title: Bis Indicator Relay
Post by: Milky on January 24, 2006, 08:31:46 PM
Hi folks
I am on another quest for knowledge.
My BIS indicators flash very slowly, probably once every two seconds, but the hazards flash at normal speed. I have traced the 'click' under the bonnet to a relay of some sort.
If I change this will it solve the problem?
If so, has anyone got one?
Title: Re: Bis Indicator Relay
Post by: Xylaquin on June 30, 2016, 12:45:57 PM
Sorry to resurrect a 10 year old thread, but the comments seemed most relevant.
I've always noticed the flasher seems slow, yet the hazards are quicker (you might even say they're up to modern-car speeds!)
My flasher relay has now died, so I'm wondering if it's worth replacing it with one of these digital ones I've seen in places (shown left in the picture). Does anyone have one of these that they can vouch for?
(https://s31.postimg.org/l2h4aryx7/relays.jpg)
Post by: Gadge on June 30, 2016, 05:29:50 PM
I've never used one but I do know that the hazards and the indicators use their own respective unit so replacing the hazard one (the cylindrical one) should sort the speed out
Post by: Xylaquin on June 30, 2016, 07:50:06 PM
Think you're mistaken Gadge, the cylindrical one is the indicators. the big chunky one near the wiper motor, separate from the fuse box, is the hazard relay.
or am I being naive?
Post by: Gadge on June 30, 2016, 09:54:42 PM
Actually your right, it is the one by the wiper motor, my mistake
Post by: mintex on June 30, 2016, 10:15:02 PM
The indicators flashed slow on ours and if i had the lights on and the brake lights it went even slower but the hazards worked fine no matter what i had on.
I changed the relay  for another standard one and now they flash fine and i can have everything on and the speed stays the same  so it was definitely a relay problem :)
As for the digital one you posted i cant comment as ive never used one.
Post by: Xylaquin on June 30, 2016, 10:18:35 PM
Cheers mintex, where did you get your new standard one from?
Post by: mintex on June 30, 2016, 11:59:05 PM
Sadly i never bought it new, i bought a job lot of relays from a scrap yard that was breaking a 126  on ebay.
I just did a search on ebay and found this but check its the right one first bud
http://www.ebay.co.uk/itm/CLASSIC-FIAT-500-600-126-850-INDICATOR-FLASHER-RELAY-ORIGINAL-STYLE-BRAND-NEW-/322172780536?fits=Model%3A126&hash=item4b02fe7ff8:g:7ngAAOSwXeJXcoiI (http://www.ebay.co.uk/itm/CLASSIC-FIAT-500-600-126-850-INDICATOR-FLASHER-RELAY-ORIGINAL-STYLE-BRAND-NEW-/322172780536?fits=Model%3A126&hash=item4b02fe7ff8:g:7ngAAOSwXeJXcoiI)
Post by: Da Londo on July 05, 2016, 11:38:32 AM
Over time the relays used for the indicators tend to get "sticky" inside, this can draw some serious current. Replacing it with NOS does the trick.
Does anyone know if the EL and ELX still use the same relay?
