For Sale & Wanted => Wanted: => Topic started by: Lina on November 12, 2011, 03:10:53 PM
Hello all,
Finally done the gearbox only to have the bolt that connects the gear linkage to the 'box shear off (luckily stuck in 2nd so could get home :) )
Before I order a new linkage with said bolts, thought I'd ask here first, as someone may have one lying around.
The bolt is a stepped sort, so need the right one.
Cheers!
Hi Lina , are you saying that you just need the bolt or are you after a complete link with the bolts. Either way I have got all the bits here. The bolts should also be fitted with a special spring washer between the link and the shafts and a self locking nut .
Hi Rusty - that's great news!
Well, it's the bolt that's snapped off (giving a nice, uniform circular movement effect to the gear stick, whilst remaining completely ineffectual ;) ), so only need the bolt really, but as I expected to have to buy the joint entirely to get the bolts etc, I was good with the idea of replacing the entire unit anyway, then I would have replaced everything apart from the gearstick and rod! So yes, first choice would be the entire joint and bolts etc, second choice just the bolt.
As you mentioned the washers and nuts, do you have those too? That would be super!
I can't believe I've been stumped by a bolt... :)
Lina with a 126 you have to expect the unexpected ???
I once fitted a rebuilt gearbox and after 10 mins of testing the clutch did not work , everything looked fine but discovered the bolt that secures the clutch release fork to the operating arm had sheared for some reason . I could get my finger tips on it up inside the bell housing but could not shift it :$
Had to take the whole box out again to sort it :o
Anyway will check out the options in the morning and will be in touch :)
LOL at 'expect the unexpected' - I'm learning that one!!
On a plus side, managed to get 1.5 miles of driving a 126 WITH a first gear under my belt before this happened, so I now can't wait until that feels 'normal' - can't believe I've not ever driven a 126 with a first gear - totally different car!! ;D I like it...!
It's all cool, as have my 'back-up car' which has been in pretty much constant use recently, so at least I'm not stuck for transport.
Give me a shout when you've had a look.
Cheers Rusty!! :)
Hey Rusty, just seen this. Have you still got any spare linkage bolts?
Marc
Funny you should say that , I just had my hand on some nuts this morning :o
Might have the bolts attached ;D
:o :lol:
Cool, only need one if you do have one. PM me with how and how much and I will sort it.
Marc
No need to PM , I am not an MP ! :P
I like to keep everything out in the open but you do get sunburnt in some odd places :o
I know that you Norfolk Rock Stars are minted so just put £100 in unmarked notes in a plain brown envelope & slip it through my letter box and I will get it sorted ;D
There go my next 6 years of royalties :(
Think I've a stalker, found some nuts hanging through my letter box this morning :o :o
Cheers Rusty :D
